Bagttery disconnection
I've heard that if I disconnect the battery for any length of time on the falco the clocks (even total mileage) will zero. Is this correct and how long does it have to be off.
I need to top up my battery on a standard charger, but have no power in the garage (which is nowhere near the flat) which means taking the battery off. I can probaably wire up a different battery from my other bike but want to know how long I have.
It makes some sense as this is the rev limit for the first period of running-in.wayno wrote:I still love the fact the the gear change indicator resets to about 6000rpm, the man from Aprilia must've been disgusted with himself for setting it so low
Therefore with the default set to 6,000 rpm, it reduces pdi set up time.
Pain in the neck after that though ....
That's a very good point, I'd never thought of it that way before. I always assumed it was them doing their environmental bit, showing that if you changed at 6K you could personally save the planet.
I wonder which one people did first when they bought the bike, derestrict or change the annoying 6K flashing light
- Willopotomas
Very rare I look at the clocks when riding (unless a $peed camera is in sight..lol.). So can't see the need of the little red flashy light thing meself. If it was an actual rev-limiter, then I could understand why.
All Aprilia's bikes that share these clocks are in a different state of tune, either from the factory or from the end user, so peak power would be in a different place on each bike, so it makes sense to have a movable peak power/change-up light.
