Urbane intech valve
Urbane intech valve
anyone tried one for their Falco?
http://www.urbaneracing.co.uk/single.htm?ipg=4865
Ive not got a Power Commander or chip yet and thinking I might do this instead
what do you lot think?
apparently it does this:
Stabilizes the bike on decel and downshifting.
Increases power and makes bike more responsive.
Reduces emissions.
Reduces emissions.
http://www.urbaneracing.co.uk/single.htm?ipg=6227
Sounds interesting but I can imagine a few problems if youve got a Scottoiler fitted that utilises the vacuum..
I like the idea, however Im put off purely on the basis of the bullshit to technology ratio.
ie:
Question 1. Why did Leon Haslam win his first ever double at Donnington inOctober 2008, then in the next race Greg Lavilla win the double at Brands Hatch?
and the crap about kneedown on a supermoto in the wet..
The unit, supplied as a kit, picks up on the vacuum take offs under the throttle bodies. It is essentially a vacuum control unit and reacts in real time with each cylinder, it decreases the resistance and allows the engine to spin up fmore freely, giving a cleaner burn and more power. It is also an infinitely variable control on pionts of high vacum, such as heavy deceleration and down changing, so the more you ask of it - the more it will work. you can also vary the effect of engine braking to suit your riding style
ie:
Yes I agree - there may be something to it but the "info" seems to have been written by a Snake-oil salesman - which is rather off-putting
There again you could ask Tim Nichols .... he has fitted one to his 190mph superbike.
Alternatively you can hear what he (and others) have to say on this BBC news report.
http://news.bbc.co.uk/1/hi/england/7953443.stm
They say it's to reduce down-stroke pressure and it can be fitted in just 10 mins .... but I'm still trying to figure out what the business-end connects to (the control end obviously connects to a TB vacuum take off).
Apparently the inventor designed it 15 yrs ago.
- Willopotomas
yep - sounds like a hill climbing falco would really benefit from this... and as he has probably already snaffled free press passes, then he can go get one for testing purposes....
well volunteered that BenWah!
