New Battery
Falcorob
New Battery
#1 Post by Falcorob » Wed Dec 29, 2010 5:15 pm
Anyone in need of one might want to have a look at this link.
Seems pretty good value to me. So good in fact that I've ordered one.
http://cgi.ebay.co.uk/GENUINE-YUASA-YTX ... 19be9b9939
Dusty
#2 Post by Dusty » Wed Dec 29, 2010 7:46 pm
Yep. Got one from those guys for my K12 a few weeks ago. Very good price. So good that I did consider buying one now for when the Falco needs one.
rick
#3 Post by rick » Wed Dec 29, 2010 10:08 pm
What does it mean by activation instructions? :smt017
#4 Post by Kwackerz » Wed Dec 29, 2010 10:34 pm
Activation kit?
I assume it's not a gel filled battery so will require filling with acid, etc before use.. which will be included?
#5 Post by Samray » Wed Dec 29, 2010 10:39 pm
FILLING INSTRUCTIONS :
1. Put the battery on to a flat, solid base and remove the foil strip from the battery.
2. Take the acid pack out of the box and the remove the plastic wrap.
3. Remove the Black sealing strip from the top of the Acid Pack and keep it to one side for use later on.
DO NOT REMOVE THE FOIL FROM THE ACID PACK
4. Press the Acid pack upside down on to the battery cell openings firmly and as far as it will go, the acid will be automaticly disperced to the correct level for each cell.
LEAVE THE BATTERY FOR A 30 MIN PERIOD
5. Remove the Empty Acid Pack and place the black sealer stip over the battery cells, press the black sealer strip down fully, once the battery is Sealed, it will not need to be opened again, doing to so will void any warranty.
6. Once the battery is filled and sealed it will need to be charged on a motorcycle battery charger or trickle charger to complete the activation process.
CHARGE ONCE FILLED TO COMPLETE THE ACTIVATION PROCESS
#6 Post by MartDude » Thu Dec 30, 2010 5:27 pm
YTZ 14S has higher CCA - 230 ; YTX 14BS is 200, tho' it has a higher Ah rating
LEEMAN
#7 Post by LEEMAN » Thu Jan 13, 2011 9:53 am
purchased it, very quick delivery, easy to prep before charging - very pleased
recommended
wayno
#8 Post by wayno » Thu Jan 13, 2011 10:39 am
I ordered the YTZ12S, should be delivered today, I got it from http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1
Very nice bloke, paypal balls up the payment and he's sent it even though I haven't repaid yet (waiting for paypal to refund me)
I took my old battery off and it was a YTX12-BS, no wonder it always seemed a bit pony.
#9 Post by D-Rider » Thu Jan 13, 2011 10:50 am
Hmmm - so if not activated it should keep ..... at that price it's probably worth getting one to keep on the shelf until it's needed.
mrapriliafalco
#10 Post by mrapriliafalco » Thu Jan 13, 2011 11:21 am
Does that def fit then as saying suitable for a few Honda models,and is it worth £15 more than the link that started this thread
wayno
#11 Post by wayno » Thu Jan 13, 2011 12:34 pm
It's a bit shorter than the YTX14-BS so you need to put a block under it to raise it up, but other than that it's the same size.
I got it because it has a higher cranking current so it turns the big pistons over easier. I'm not sure whether it's better to have more storage (12ah instead of 11.2ah) or a higher starting current (230 instead of 200), but for me either one will be better than the YTX12-BS that was in there which has 10ah storage and 180 cranking current.
Here's the specs of the 2 being discussed
Manufacturer: YUASA
Battery type number: YTX14-BS
Battery type: Sealed maintenance-free battery
Filling kit included: Yes
Dimensions: 150mm x 87mm x 145mm
Capacity rating: 12Ah
Cold-start performance: 200EN
Terminal layout: Left: + Right: - (With the terminals on the edge nearest to you)
Manufacturer: YUASA
Battery type number: YTZ14S
Dimensions: 150mm x 87mm x 110mm
Capacity rating: 11.2Ah
Cold-start performance: 230EN
Maximum charging rate: 1.5 Amp
Weight (filled): 3.9kg
If you want the higher cranking current but not the higher price then you could use one like the CTZ14-S (the first letter is only the manufacturer name) http://www.mad4bikes.co.uk/batteries-ge ... p-598.html
I went for the one from e-bay because I've used Yuasa and numax in the past and have had no problems, I would rather spend the extra £15 and have a name I know (but that's personal choice)
wayno
#12 Post by wayno » Mon Jan 24, 2011 1:13 pm
Fitted the battery at last, she burst into life within about 1/2 second of pressing go. Not bad as the bike's been sat all winter in the garage homing a mouse.
Yes, a mouse has been living under the back seat of my Falco, it would appear the little b*stard has been going into my fishing bait bag, nicking dog biscuits then storing them under the back seat of the bird. I gave it a good hard thrashing just in case it was still 'home'.
I think it's time to put the fishing gear in a big metal box, it would appear a big concrete box isn't enough to stop a mouse.
#13 Post by MartDude » Mon Jan 24, 2011 6:13 pm
wayno wrote:Fitted the battery at last, she burst into life within about 1/2 second of pressing go. Not bad as the bike's been sat all winter in the garage homing a mouse.
Pardon my ignorance of matters piscatorial, but do fish like dog biscuits?
wayno
#14 Post by wayno » Mon Jan 24, 2011 8:12 pm
Yeah, carp love them in summer, mice love them in winter, apparently
#15 Post by Nooj » Tue Jan 25, 2011 12:51 am
Maybe you should keep a carp under the seat. It would eat the biscuits the mouse brings in, thus pissing the mouse off so it goes somewhere else.
