sky plus box
paddyz1
sky plus box
#1 Post by paddyz1 » Tue Dec 28, 2010 8:25 pm
Does anyone know if you can copy stuff off the sky plus box onto computer. There is a usb on the sky plus but the instructions say nowt about it. I will try and connect myself but not sure if it will work. got to go find a lead now.
cheers
#2 Post by Aladinsaneuk » Tue Dec 28, 2010 8:50 pm
no - not easily
the usb connection, is, iirc, a way of updating the units software
two options - one is to use svhs leads and a video capture card on a pc or take hard drive out and then rip using assorted PC software utils
I believe that the way that skys stuff is encrypted is also a bit of a bugger - ie, free to air stuff should be fairly straight forward, sky movies etc... nasty
back_marker
#3 Post by back_marker » Tue Dec 28, 2010 8:51 pm
As i understand it, the USB ports on all Sky boxes, including the latest ones, are not set up to do anything. They have a power supply and will charge stuff but won't actually communicate with anything. Tried plugging an external hard drive into mine a little while ago and it didn't do anything, I think it's just something they included on the design just in case they want to use it at a later date.
The hard drive itself is just an ordinary IDE item which you may be able to remove and connect into a PC or caddy but I seem to remember being told once upon a time that they stuck some kind of crazy firmware on it which is peculiar to Sky boxes.
- Steve McQueen
paddyz1
#4 Post by paddyz1 » Tue Dec 28, 2010 9:34 pm
Ah well, thanks guys. I wanted to copy twist of the throttle that was on turbo the other night.
there was about eight, 1 hour shows on various makes of bike.
Moose
#5 Post by Moose » Fri Dec 31, 2010 10:57 am
I know you can transfer recorded material to tape/dvd or another hard drive recorder (while watching the programme :smt011 ) which is a pain to say the least. :smt018
But of course Sky likes it that way! I have only transfered to tape and it worked fine :smt001 .
I too thought "usb" easy peasy :smt003 but as previously stated it is just for future upgrades :smt019
