General Aprilia banter
Falco9
#1
by Falco9 » Thu Dec 16, 2010 8:28 pm
I need to re-order some stainless steel bleed nipples for the Falco and would be grateful if anyone could tell me the actual size of the nipples please? I've done a search with no joy, but looking at them (front caliper)and using my trusty ruler I reckon they are a M8 x 1.25. I'm assuming (dangerous I know) that the rear will be the same size
I ordered a set of 3 stainless HEL bleed nipples from a company called Moto-Racing and the ones they have sent are definately M10 and are too big for my goldline calipers (PS Don't waste your time with this outfit, they don't answer either e-mails or the phone, looks like I'm stuck with these bleed nipples)
F9
#2
by D-Rider » Thu Dec 16, 2010 8:32 pm
Falco9 wrote:Bleed Nipples
Ah the old jogger's problem.
I think you probably need some vaseline and a good sports bra.
#3
by Falcopops » Fri Dec 17, 2010 1:33 am
I'm pretty sure they are M10, but with a 1mm pitch thread.
Falco9
#4
by Falco9 » Fri Dec 17, 2010 9:07 am
Found a good but bl**dy obvious way of checking................I got out my tap & die set and ran the nipple through a die to check
I'm pleased to report that my aging eyesight and good (questionable) judgement was right they are
M8 x 1.25 but after doing more t'internet research last night the M10 x 1 ones might be for the later radial calipers
F9
#5
by mangocrazy » Fri Dec 17, 2010 6:16 pm
Falcopops wrote:I'm pretty sure they are M10, but with a 1mm pitch thread.
I'd go with that, as well - M10 x 1.0mm. That would be for standard front Brembo Goldlines, if memory serves correctly. Unfortunately as I'm estranged from the bike at the moment (no cause for alarm, just a temporary separation), I can't check to be sure.
Falco9
#6
by Falco9 » Fri Dec 17, 2010 8:14 pm
mangocrazy wrote:Falcopops wrote:I'm pretty sure they are M10, but with a 1mm pitch thread.
Nope they are definately M8 x 1.25 for the goldline calipers (well the ones fitted to my calipers are that size)
F9
#7
by Falcopops » Sat Dec 18, 2010 4:17 am
interesting, I just looked at the torque settings for the bike and it dos say M10 x 1.0. on reflection M10 does seem a bit big for the bleed nipples though and you've verified the actual item so a lesson learned.
#8
by D-Rider » Sat Dec 18, 2010 10:05 am
Well I've not been out to have a look but is there any possibility that each is right but for each of the threads?
One of them where you screw the whole thing in to whatever you are bleeding and the other for the bit you crack open to bleed it?
(note the excellent use of technical terms in the description).
Probably not the case but it was just a wild thought.
#9
by Nooj » Tue Dec 21, 2010 10:29 pm
Is it M10 for the front calipers and M8 for the rear?
Tweaker
- Main bike: BMW R1250RS
#10
by Tweaker » Wed Dec 22, 2010 11:16 am
Oh for heaven's sake - definitive answer......
M10 is for Chiswell Green
M8 is for Glasgow
End of
- Double World Champion
#11
by Samray » Wed Dec 22, 2010 11:45 am
#12
by D-Rider » Wed Dec 22, 2010 11:06 pm
Tweaker wrote:Oh for heaven's sake - definitive answer......
M8 is for Glasgow
End of
..... and I thought M8 was text-speak for one of your chums ......
Tweaker
#13
by Tweaker » Thu Dec 23, 2010 3:05 pm
Dunno.... haven't got any - you lot are it
Falco9
#14
by Falco9 » Thu Dec 23, 2010 4:42 pm
Little did I think such a simple request would lead to such a long ( and somewhat boring thread)
The answer is that the bleed nipples on the Falco (running std goldline calipers) front are
M8 x 1.25 and rear caliper is
M10 x 1.0 so don't believe the hype (or the manual)
F9
