With a std length chain could I fit a 15-42 pair of sprockets?
I know a 15-41 will fit (I used to run it) but fancying a slighty shorter gearing set up this time round
F9
No problem, although IMHO I reckon you would struggle to feel the difference with just one tooth difference on the road, but you might find the odd corner / roundabout is better.dyzio wrote:Can you refresh this thread after you've put some miles on with the 15-42 combo?
I'm running a 15-41 set, which feel good, but I'm wondering if the 42 rear will feel better
