Swinger
ste
Swinger
#1 Post by ste » Tue Nov 16, 2010 6:01 pm
Which is the best way to get the needle roller bearing out of the swinging arm. why the engine is out of the frame is anything else to be looked at.
#2 Post by Willopotomas » Tue Nov 16, 2010 6:07 pm
couple of deep sockets and a g-clamp.
one socket small enough to press on the end of the shell of the bearing but not the swingarm and the other large enough to allow the bearing to pass into it but to rest on the swingarm. Place the smaller socket on the bearing and the larger one on the opposite side.. Then put the g-clamp over the ends of the sockets and tighten. The smaller socket will push the bearing out the opposite side into the deeper socket..
Bit difficult to explain really.. but I hope you get the jist of what I'm trying to say..lol.. :smt001
ste
#3 Post by ste » Tue Nov 16, 2010 6:11 pm
Thanks,i,ll have a go tomorrow after i take my frame for welding. :smt012
#4 Post by Willopotomas » Tue Nov 16, 2010 6:36 pm
Ally welding.. nice.. NOT! Hope you take it to a decent place where they can stress relieve and crack test it.. :smt002
ste
#5 Post by ste » Tue Nov 16, 2010 7:47 pm
Should be ok Gia frame builders, the chap worked at spondon engineering for 20 yrs,( spondon frames)
#6 Post by Willopotomas » Tue Nov 16, 2010 9:35 pm
a most excellent result there my friend..lol.. :smt003
#7 Post by D-Rider » Tue Nov 16, 2010 11:49 pm
Willopotomas wrote:couple of deep sockets and a g-clamp.
errrr .... from what I remember you can't easily get anything on the back end of the bearing to drift it out. You may stand a chance with one of the more fancy bearing pullers but I ended up cutting mine out using a dremel thingy.
#8 Post by Willopotomas » Wed Nov 17, 2010 12:14 am
I forgot to add that I've no idea what it's like for space. But that'll be the usual way of doing it.. Other ways are with the aid of a slide hammer, mallet n' drift or as Andy say's.. Cut it out.. :smt002
#9 Post by Falcopops » Wed Nov 17, 2010 12:31 am
There's a shoulder behind the bearing that prevents it being pushed right out the opposite side of the swingarm.
A blind bearing puller might do the job, but who's got one of them?
+1 for cutting it out.
