electrical questions - part two....
#1 Post by Aladinsaneuk » Sat Sep 11, 2010 1:56 pm
ok folks, bear with me....
now looking at fitting a switch to a light in the work shop
I am ignoring the earth lead for this - I can see where that bugger goes.... - the terminal inside the switch marked earth!
I have two cables - one from the power, one from the light
both cables are the same - one brown lead, one blue lead
(Brown for live, Blue for neutral)
I have a switch which i want to use
it has three terminals - one marked COM one marked L1 and one marked L2
So - what goes where?
I am guessing that Power brown goes to COM
I am also guessing that Light Brown goes to L1
So - Both Blue leads connect to L2?
that correct?
#2 Post by D-Rider » Sat Sep 11, 2010 2:13 pm
NOOOO It'll go BANG
You won't be using L2 unless you have a 2-way switch arrangement.
To save me having to draw pictures, here's what you need to know:
http://www.diyhowto.co.uk/projects/one-way-lighting.htm
#3 Post by Samray » Sat Sep 11, 2010 2:33 pm
:smt017 :smt115 :smt073
#4 Post by Kwackerz » Sat Sep 11, 2010 2:38 pm
Stick to exhaust porn mate.. Electricals @240volts doesnt sound your thing!!
#5 Post by Aladinsaneuk » Sat Sep 11, 2010 2:38 pm
i knew you chaps would know :)
thanks
#6 Post by D-Rider » Sat Sep 11, 2010 2:45 pm
I've got one for you too.
I've cut my little finger. I think I should clean it with cold water and then put a plaster on it.
I'm guessing that to finish the job properly I should then sever my head with a chainsaw?
:smt017
#7 Post by Aladinsaneuk » Sat Sep 11, 2010 9:09 pm
i ran the question by a friend of mine - he popped over and sorted stuff out for me
- another friend popped in - he wet himself as he gets me to rewire assorted bikes and trikes for him - but thats easy - only two wires - none of this neutral bollocks....
#8 Post by HisNibbs » Sat Sep 11, 2010 10:14 pm
D-Rider wrote:NOOOO It'll go BANG
You missed an opportunity!
Suppose there'll be many more.....
#9 Post by Samray » Sat Sep 11, 2010 10:36 pm
:smt082
#10 Post by Aladinsaneuk » Sat Sep 11, 2010 10:44 pm
mutters
