What's your favourite colour scheme?
Blimey can't even you mods fix things?Kwackerz wrote:I dunno.. the Kawasaki Green one rocks! As does the Mango one! I think personally im torn between the two. Ive ticked Green, however I'd have ticked mango as well if it had been possible.
I'm thinking of colour coded logos, just to blend with the other templates a little.
Also, the poiple one is the lushest IMO, but all of the colours are pretty nice.
Subsilver, well that's the most worksafe I've found (so I'll be seeing a lot of that I guess).
The Tiger one just seems to sum up the spirit though, which is nice.
Support RiderSite!
Kwackerz wrote:![]()
If Hammy'd used VBulletin, then Yes, however phpBB is the beast that we are all accustomed to.
And besides... VD uses VBulletin!!![]()
But then VD is a bit garish itself
Don't really understand why you say sub sliver is the only worksafe one, surely they all are!Hammy wrote:![]()
After all its pretty easy to use key strokes to reduce it to a minimum if the boss is about.
They don't have to be, for example on the bar at the bottom of the screen its got a bar that says 'RiderSite.com'Kwackerz wrote:Yes, but not all Bosses are colourblind...
I was wondering if there's a way of hiding the tab on the bar at the bottom (no I don't mean it pops up when you hold the cursor over where it should be).
Once the screen is open, just remove the bar totally. Click the top edge of the toolbar, hold the button down and drag downwards...etc, etc
Just becomes a pain when you need it!
Especially if you're running a prog that 'you' should be working onKwackerz wrote:Once the screen is open, just remove the bar totally. Click the top edge of the toolbar, hold the button down and drag downwards...etc, etc
Just becomes a pain wehn you need it!
