Direction Needed..
- Willopotomas
Direction Needed..
.. to any relevant posts about the rear brake and how to improve. My guess is the master cylinder is too small as it seams to run out of poke before it's begun to start working. I've heard that the back brake isn't the best, but FFS, the rear SLS drum on my 44 year old Triumph is better than that!
- Willopotomas
I've managed to bleed it a bit differently than KZ's method:
- take the calliper off, position it so that the bleed nipple is at the lowest point,
- pump brake fluid through the bleed nipple upwards a few times,
- push the pistons back into the calliper,
- reverse bleed again,
Worked for me
EDIT:
Also I've adjusted the rear brake rod, #8 here:
BUT:
IF YOU OVERDO IT, YOU'LL BOIL THE BRAKE FLUID AND YOUR BRAKE WILL SIEZE!!!
Worked for me
EDIT:
BUT:
