left side switch gear
LEEMAN
#1 Post by LEEMAN » Mon Aug 23, 2010 2:27 pm
before I go trawling through Flea bay, just wondered whether any of you lot had a spare left sided switch gear?
Ive been without a proper headlight now for some time, if I turn my handle bar to extreme right then I have both light and horn but otherwise its buggered.
Ive searched for a break in the wire, had a specialist look at it too and the conclusion......i need a new one.
Dave
#2 Post by D-Rider » Mon Aug 23, 2010 2:46 pm
From the symptoms I'm pretty sure it's a wiring problem.
From the wiring diagram, my chief suspect would be the Green wire to the switches.
