Spotted on ebay - tank prop
#1 Post by D-Rider » Mon Jul 19, 2010 12:33 pm
On a buy it now .....
http://cgi.ebay.co.uk/Aprila-RSVR-RSV-M ... 563e1de4bb
Item number: 370409333947
paddyz1
#2 Post by paddyz1 » Mon Jul 19, 2010 4:23 pm
You can get these off an rs125 as well. Our 125 has been sold now but i kept the tank prop and the holding clip, which fits perfectly in the machined hole on our subframes (left side under seat hump)
#3 Post by Willopotomas » Mon Jul 19, 2010 5:16 pm
Don't need one.. Already got one tucked under the rear hump. :smt003
#4 Post by fastasfcuk » Mon Jul 19, 2010 5:58 pm
thanks andy, got myself a tank prop.
#5 Post by HowardQ » Tue Jul 20, 2010 11:10 pm
Bugger just missed the last one.
Then again just bought a gear lever and linkage, whilst browsing.
Botched mine with a thin washer to help take up the free play to get it through the MOT a couple of weeks ago.
Actually the botch worked very well, the change is so much nicer now, should never have let it get that bad. :smt009
So thanks anyway Andy!! :smt023
#6 Post by MartDude » Tue Jul 20, 2010 11:23 pm
Is the prop really necessary on a Falco? On the Fut, the tank stays up by virtue of the friction in the mount/pivot at the rear of the tank. If worried about vibration shaking it down, put a block of wood underneath (picked that up form Griff).
#7 Post by D-Rider » Tue Jul 20, 2010 11:35 pm
MartDude wrote:Is the prop really necessary on a Falco? On the Fut, the tank stays up by virtue of the friction in the mount/pivot at the rear of the tank. If worried about vibration shaking it down, put a block of wood underneath (picked that up form Griff).
The Falco tank won't stay up without something to support it.
#8 Post by HowardQ » Wed Jul 21, 2010 12:19 am
It's back to the big lump of wood for me then!
Hishy
#9 Post by Hishy » Wed Jul 21, 2010 5:42 am
Thats wierd mine doesn't without the prop it would just fall down, and the prop doesn't work very well once the airbox is out so i now tie it up the the roof of my garage :)
#10 Post by fastasfcuk » Wed Jul 28, 2010 1:28 pm
right were's this bloody thing fit.
you're going to tell me it fits in the air box are'nt you. :smt012
#11 Post by D-Rider » Wed Jul 28, 2010 1:43 pm
When in use, you stick one end into one of the holes in the bracket that secures the front of the tank and the other goes in the hole in the top yoke fixing.
When not in use, it goes under the passenger seat - original ones came with fixing clips mine just slots in to a gap in there.
#12 Post by fastasfcuk » Wed Jul 28, 2010 4:07 pm
i've got my tank bag thingymejig in there. :smt010
#13 Post by D-Rider » Wed Jul 28, 2010 4:27 pm
fastasfcuk wrote:i've got my tank bag thingymejig in there. :smt010
Same here ..... you need to remove it when propping the tank ..... though you've probably figured that for yourself
