Brake Fluid
Brake Fluid
Changing the fluid in the brake lines at the weekend , sure the last time I used 5.1 synthetic am I right in saying that this grade is more suited to heavy use .
Hi John1000, I believe there were issues with what was considered a race item Dot 5.1 fluid, some formulas eroded rubber seals. I believe most formulations are now OK but read this http://www.xs11.com/tips/maintenance/maint1.shtml
- loafersmate
There was a big discussion on AF1 on this.
From memory (ie This Needs Checking Before You Act On It) it's OK to use DOT 4 or 5.1 but not DOT 5 as it's quite different. I'm pretty sure they concluded that the DOT 5 was a misprint because it isn't the same as DOT 4.
I'll go and search for this and edit this if I find anything.
EDIT:
Yep read these links to discover more:
http://www.apriliaforum.com/forums/show ... hlight=DOT
I'd read these in conjunction with the link posted by Thumper for the best understanding.
Anyway - the advice is Avoid DOT 5
EDIT:
Basically you don't need dot 5, dot 4 is more than adequate for a road bikes so that's what I use.
However fluid speck moves on and more manufactures are producing higher spec fluids now.
Many falco owners were having problems with clutch cylinders leaking in the last few years and I was reading about troublesome brake master cylinders also, these things are usually very reliable.
I suspect the systems were being filled with Dot 5 fluids and it was causing premature failure of seals but It's only a hunch, I have no evidence for that.
Always expect the unexpected
Just to add some confusion:
http://www.apriliaforum.com/forums/show ... stcount=12
Just as on our forum, over on AF1 some posts within a thread are more helpful than others.sabestian wrote:Just to add some confusion:
Read the whole thread, understand what is consistent and check against other authoritative sources -like the link that Thumper posted.
- Falcoholic
