some post mod thoughts
#1 Post by Aladinsaneuk » Wed Jun 23, 2010 12:46 pm
(I did also post this on AF1 so some may have seen it before)
just thought i would share a few thoughts for folks - that may help some newer falco owners consider mods etc and their actual benefit
For this year - well, till winter, Hanna's oasis green is now finished
When we got the bike it was standard bar braided brake lines. now as it was sharing the garage with my slightly breathed on black stealth falco, it had to be fettled a bit
this evening I took it out for a little exercise on my private track to give it a good work out
last time i rode it on the private track it was standard - unrestricted but standard.
so - some thoughts and comparisons - both to its original form as it arrived and compared to my ickle beastie.
First thing that had to be fitted was some exhausts - the original cans were a nice colour - black, but very poxy - no noise, limited response etc. some carbon can company cans - no baffles ossifer, were fitted. These are actually louder than my renegades! they do bark well - and they do have an impact in the mid range - pick up is pretty cool Riding with them means you need ear plugs, but - well worth it I think
next, I looked at the indicators - the standard ones are far to ugly - - bit like realising you have a red haired step daughter - then noticing she has a hair lip and hump.... I swopped these over to some smoked units - am not overly happy with them - they look ok, but... i need to work on them.... so why mention them... well, my falco has the correct early switch gear - the latter stuff is awful - kept trying to put the horn on etc! they will be changed this winter - i will take time to find the right look. (Having said that I have a new mod I am working on for my falco that may help.....)
all modern bikes have a poultice at the arse end - so i needed that sorting it. I made a bracket and popped everything neat - no changes needed - a tail tidy does make a nice aesthetic change - ie, do it
having sorted the exhaust, i knew i needed to do something on the intake side. Bearing in mind Hanna has only recently moved up to a 1000 i felt a renegade or evo was not a good call - so a K&N was fitted.... that bugger is going this winter
Finally, the rear shock was switched to a white spring mille shock - and then the suspension was set by griff - UK folk know that he is the man for all things aprilia
(I did sort the sidestand btw - all none USA folk should do this when they collect their bike....)
So - the riding test
First impressions were very positive - though I weigh a few pounds more than hanna, the bike was planted in the corners - i threw it through several sets of twisties on the private track and it rode well - compared to the original blue spring sachs shock which did wallow
Long and the short of it - if you are a decent rider who does like to work the bike out - change the shock.
(My bike has a WP fitted - is it worth the average rider spending that kind of cash - no!)
Now performance....
The falco, derestricted, is a swift bike. Lets be serious about that The open pipes, and free er air filter did make it move a fair bit better. BUT
Compared to my beast, with the open renegades and airkit with 54mmm throttle bodies - not even close.
The throttle bodies, combined with the other stuff give a shed load of mid range power - hanna's bike is good - but - i would find it very hard to go back to that performance now.
(So - for the real performance hunters out there - renegades all round, 54mm bodies and then you will have fun - and yes, that level of performance is beyond my skill as a rider - but i do like it!)
guess the moral is simple
the falco is a really awesome bike
a little bit of fettling makes it very special
if you are prepared to throw a few quid at it, then it will quite happily do all that you ask of it - I am not a quick rider - but there are an awful lot of local rice burners around where i live who struggle to keep with me
oh - pound for pound - the best mod done to hanna's bike - sort the suspension out - not only with a new rear shock, but get it set up for you
Renevator
#2 Post by Renevator » Wed Jun 23, 2010 12:52 pm
Interesting reading - thanks. Regarding the K&N - you give the impression it's a duff call just installing that. Is that the case? The renegades etc that you've got to improve performance - do they improve tractability at low revs (i/e town stuff) or the opposite. I'm just collating info for my future mods :smt002
#3 Post by D-Rider » Wed Jun 23, 2010 1:05 pm
K&Ns are worth it in my view - clean them and re-use them - makes sense to me rather than fitting a new one each time
sabestian
#4 Post by sabestian » Wed Jun 23, 2010 2:02 pm
Renevator wrote:The renegades etc that you've got to improve performance - do they improve tractability at low revs (i/e town stuff) or the opposite.
It did in my case. A lot.
#5 Post by Aladinsaneuk » Wed Jun 23, 2010 6:48 pm
i am not saying they are bad
but
they are 25 quid a pop
for 50 quid you will get an evo kit - and that will have a real performance boost - like 5hp
the k&n helps with breathing but does not, imho, increase overall performance
(and for the arch fettlers a diy evo is around 10 quid....)
#6 Post by MartDude » Wed Jun 23, 2010 7:02 pm
My two penn'orth. (NB I'm talking about a Futura)
I fitted a BMC filter (local stealer was doing a special offer). It hasn't made any difference to top-end, but it seems smoother through the mid-range - breathing more easily. And it sounds a bit more interesting.
Tractability at low revs - cheap option is a smaller front sprocket. Works a treat - loads of fun for about £17.00 I mean, you'd be pushed to get a blow job for that.
And Pete, what's wrong with redheads? http://www.dailymail.co.uk/news/article ... ettes.html
Spent a couple of happy years with a redhead. And my daughter's a spectacular redhead - which I now find somewhat worrying.
#7 Post by Aladinsaneuk » Wed Jun 23, 2010 7:30 pm
pictures and phone number please mart....
and before malteaser gets pissy she should remember:
a blonde is a red head with the fire shagged out of her., a brunette is a sympathy shag while you imagine a red head.......
Midnight Rider
#8 Post by Dalemac » Wed Jun 23, 2010 9:06 pm
K&N filters and alike dont have to be replaced, they can just be cleaned and re-lubed.
As for the performance, i definately noticed a difference when i installed my pipercross filter. it makes it a little more managable lower down the rev range.
#9 Post by D-Rider » Wed Jun 23, 2010 9:28 pm
MartDude wrote: And Pete, what's wrong with redheads?
Karen Gillan certainly has made Dr Who even more entertaining ...
Not sure I remember this episode though:
#10 Post by HowardQ » Thu Jun 24, 2010 12:03 am
Lots of good info there Pete, many thanks. :smt023
Noeli0
#11 Post by Noeli0 » Thu Jun 24, 2010 7:47 am
Nice write up thanks, as being new to this its good to hear what mods have the best effect
I think I might need to organise a trip to Griffs to sort out suspension
Jadaris
Malteaser
#12 Post by Jadaris » Thu Jun 24, 2010 9:02 am
Aladinsaneuk wrote:pictures and phone number please mart....
Ok so what the hell am I, meeting you really has removed the fire from my hair then :smt005
So a red head is a virgin?
