new fella needing a Falco
zoidberg
#1 Post by zoidberg » Mon Jun 07, 2010 9:40 pm
chaps :smt006
i'm after a falco and have currently set my sights on a 2005 model which hopefully i'm going to look at this weekend.
What do i need to look out for?
I will order a new sidestand if i buy it. the rear shock has been replaced already.
What else do i need to be putting on my shopping list. I'm used to heavy clutches, so not too bothered about that.
What's the benefit of fitting a mille swingarm?
and also i'll be needing some cans to let it sound how it should.
i've seen some pipewerx ones on ebay are they any good?
and a new eeprom? where could i purchase of of these?
sorry for the inquisition.
thanks in advance
Dave
#2 Post by fastasfcuk » Mon Jun 07, 2010 9:56 pm
welcome zoidberg, hope you find a bike soon. as for mods were going to blow your mind. :smt003
#3 Post by Kwackerz » Mon Jun 07, 2010 9:56 pm
Welcome Dave, One of the Falconeers will be along shortly with your answers :smt001
Somebody check his credit rating... this could get messy... :smt005 :smt005
Re: new fella needing a Falco
#4 Post by D-Rider » Mon Jun 07, 2010 10:20 pm
zoidberg wrote:chaps :smt006
thanks in advance
Dave
Hi and welcome Dave.
Guess it's 2005 registered - last ones were made in 2004 (mine's 2005 registered).
Swingarm mod - no practical benefit other than bling ... but it's good bling ...
First things first, forget all the other mods until you've:
  • 1) sorted out the sidestand
    2) sorted out a rear shock - Ah, just re read it - that's done then
Never come across Pipewerx cans - sorry
Chips ... well chips and/or PCIII
Chips vary - most only play with fuelling but the Renegade, Factory Pro and Gabro chips also adjust ignition timing.
Also heard good things of DrRossi chips but still not managed to confirm whether they play with ignition timing.
dyzio
#5 Post by dyzio » Mon Jun 07, 2010 10:24 pm
Howdoo!
The usual I would say, plus from my experience if the bike struggles to start and needs jump leads - the battery will go soon.
Bubseywoo on ebay or US version (about 100 pounds)
I thought the clutch wasn't that bad but I've put a MPL slave on, noway I'm going back!
Some say it gives you extra 12bhp ;)
Ohhh yeeess, and no idea about pipewerx
Try Gabro on AF1
no worries
thanks in advance
Dave
Hope this helps a bit.
#6 Post by HisNibbs » Mon Jun 07, 2010 10:25 pm
To go with the Cans one of the variouse air box mods will add a certain something.
#7 Post by Kwackerz » Mon Jun 07, 2010 10:29 pm
BHP, Speed and performance with the SL1000 is determined by colour.
Which colour are you looking to buy?
#8 Post by Falcopops » Mon Jun 07, 2010 10:38 pm
Kwackerz wrote:BHP, Speed and performance with the SL1000 is determined by colour.
That's a touch racist is it not? especially coming from an employee of HRH.
Welcome Dave,
All your point's have been covered already, my tuppenceworth would be to wait until you've got all your performance mods in place before deciding on a chip, unless you go the PCIII route.
zoidberg
#9 Post by zoidberg » Tue Jun 08, 2010 12:14 am
red & black :smt004
could someone be so kind as to compile a quick list of essential mods for me please :smt003
the priority will be that sidestand of course.
i had an RS125 when i was 17 and the sidestand was made of chees on that too.
every time the wind picked up i'd come out to the bike laying on it's side.
:smt011
and thanks for the welcome.
great site :smt023
#10 Post by Falcopops » Tue Jun 08, 2010 4:26 am
This is a sticky in this area of the site, reasonable starting point.
#11 Post by Aladinsaneuk » Tue Jun 08, 2010 6:27 am
welcome
may i suggest that you sort the sidestand - bubseywoo is probably easiest - around 50 quid
talk to the seller - find out the bike history - especially valve clearance che ks/shims
as for other mods - get it, ride it and look here - there will be lots that will interest you - and lots of different stuff....
#12 Post by DavShill » Tue Jun 08, 2010 6:54 am
Welcome - hope you get fixed up. Great bike and very helpful and reliable advice on this forum.
We will spend your money faster than you can earn it I'm afraid :smt002
rick
#13 Post by rick » Tue Jun 08, 2010 8:09 am
Welcome and great news on your bike choice :)
I'm relatively new here but ended up buying my Falco off a member here and have never looked back. Mine had the usual
mods, FP chip, rene air box, maxton rear shock and scorpion end cans - the problem I have is that I've only ever ridden a Falco with these mods and so cannot comment on what it's like without these!
Only thing I had to do ASAP was sidestand... got advice off here and ended up getting a VTR firestorm one and it does the job!
I've also done a few cosmetic things (tail tidy, exhaust hangers) and now my clutch slave seal is weeping I'm toying with idea of MPL and then braided hoses all round.
Anyway enjoy ur new purchase! Get your credit card ready!
#14 Post by HowardQ » Tue Jun 08, 2010 12:30 pm
Welcome to the site Dave. :smt006
Just the usual things to look for. (as mentioned by others already), as Falcos are very reliable if looked after and don't corrode as bad as most if used in winter, (I've run mine through six winters).
The Falco's big V Twin is not an easy thing to turn over, but mine has always started first time if the batttery is up to it. Take great care and if the battery is low charged, it as it can damage the Sprag clutch and cause dash resets with EFI displayed. Best to keep it on an optimiser of some sort then even an older battery should be OK for a while. If it does need a new one see the threads on here about batteries with a higher turn over capacity, which can be worthwhile)
As for cans, yes get some, but never heard of Pipewerx, I use Beowulf cans, as do a few others on here. They are fine with the standard chip if you leave the baffles in. They are bloody loud with them still in!
I fitted a K&N filter at the same time and they worked perfectly together.
Others have fitted Blue Flame and Fuel and they seem to work well.
I would fit a hugger early on to keep any crap off the shock.
Good luck with your search or purchase if you go for the one you've seen.
Only problem is they always say never buy the first bike you see, but you don't see many Falcos!
#15 Post by Aladinsaneuk » Tue Jun 08, 2010 1:26 pm
oh - look in for sale section - flying kiwi has just listed his falco....
and if you cannot find a rear hugger, then go for a shocktube - nooj is a dealer....
