took it for it's medical yesreday.as expected no problems.
but talking to the tester regarding a couple of earlier post ie number plate lights and exhaust.new legistlation states that you are only required to have two rear lights ie tail and brake. a fitted number plate light that does'nt work is not a failure.exhaust even with baffles out are'nt a failure unless stamped not for road use.no other stamps are required.as for noise they can't fail, only advise because no testing equipment is available.
mot a breeze
