Bridgestone !!!!
- mrapriliafalco
Bridgestone !!!!
Has anyone bought 016s or 023s?
Are the 016s triple compound so are the 023s gonna last much longer.
- HowardQ
Bit early to comment on tyre life of a BT 023 yet, they only went on sale in May.
I seem to have been using Bridgstones for ever.
used 010s 020s 021s and 014s.
Quite often mixing them with the sportier version on the front.
Usually got more miles from the 02?s.
Until I tried the 014 front 021 rear combination which worked better and lasted better on the front than my curent 021 F & R set up on the Falco. (My best combination on the Falco and the old CBR1000).
Then again the 021 front uneven wear problems have been reported by a few people, hence the 023 replacements.
Certainly if the 016 is as good as the 014, I would expect it to wear well and be a good sports road tyre.
It's getting pretty confused at the moment with all sorts of people claiming that their sports tyres the also grip well in the wet and last like a sports touring tyre. Things like the Dunlop Sport Smart and Metzler M5.
Hope they do turn out this good.
Take a ride on the Dark Side
- mrapriliafalco
- Falken
Not done a lot of miles on it yet but grip feels better than the 021 and 020, but it's got that silly earthing strip showing already around the middle.
What it didn't say in the write up was how it contacts to the rim, if it doesn't, how can it be to release static?
Adventure before Dementia.
- anzacinexile
- mrapriliafalco
- anzacinexile
How about going through 2 1/2 fronts to one rear. Wears really strange, like an 50 pence coin. Plenty of tread in the middle and the far edges but worn through at 45' on the flanks, straight as a ruler.mrapriliafalco wrote:What happened with the 21s
The 20's never had that problem and for a while, I managed to fit a 20 front and a 21 rear and that combination was brilliant. Cant find any 20's any more so hence my defection to Pirelli's
In this month's PB there is a review of tyres and it seems to be a bit more objective in its approach than many I've seen - and the riders were sent out not knowing which tyres they had fitted to minimise personal prejudice.
Perhaps most of the tyres are a bit more sport oriented than a lot of us use but the BT016s were included.
They didn't come last .... quite .... but there was only one tyre below them.
Top tyre was the Pirelli Diablo Rosso Corsa - which is their new one. I've been running the Diablo Rosso for a while now (non Corsa variety) and think it excellent - so I'm not surprised.
Another that stood out was the Maxxis - it held its own being placed in the middle of the pack but a pair were £50-£60 less than most on test.
If I remember I'll stick up a quick summary tonight.
For a more full description, get a copy of PB ......
- back_marker
Did this on my wife's VFR after her front 021 went the same way. After some ringing around managed to get one fron Micheldever tyres on the A303 in stock and fitted for about 90 quidanzacinexile wrote:How about going through 2 1/2 fronts to one rear. Wears really strange, like an 50 pence coin. Plenty of tread in the middle and the far edges but worn through at 45' on the flanks, straight as a ruler.mrapriliafalco wrote:What happened with the 21s
- Steve McQueen
- Steve McQueen
- mrapriliafalco
