So just how easy is it?
Falcorob
#1 Post by Falcorob » Sat May 29, 2010 9:49 pm
To fit a MIlle shock to a Falco? :smt002
#2 Post by Aladinsaneuk » Sat May 29, 2010 9:51 pm
depends on which one - linkages etc
BUT
if you have an abba stand, or have a friend with one, less than two hours start to finish
you will need a torque spanner....
(ie, very easy - just take your time)
#3 Post by Nooj » Sat May 29, 2010 10:59 pm
From memory, the hardest part was was working out which way to turn them to get them out of and then back into the swingarm.
If you have a hugger, take that off first.
old git
#4 Post by old git » Sun May 30, 2010 4:09 am
OK, twas not mille shock, was Ohlins did it about 4-5 weeks ago.
Once you have the back in the air to take the weight off the rear wheel, is a piece of cake.
Undo bolts, slide old blue out, slide in new shock, do up bolts thats it.
OK I don't have a hugger in the way, found it easiest to pull the old shock out from below.
Best of luck.
sabestian
#5 Post by sabestian » Sun May 30, 2010 8:01 am
Don't forget to change the swingarm to a Mille one while you're there. :smt003
