quick answer about chip
- mrapriliafalco
- anzacinexile
Yes but not sure about the pedigree or how well it will perform. Bit concerned about the bullshit about the "top end governor", sounds a bit like snake oil to me
Personally I wouldn't risk it - I would go with a chip that is known to work well like the FP or head over to AF1 and ask for Gabro, his chips are pretty good
- mrapriliafalco
- Falco9
Sounds like complete bo**ocks to me TBH
Natural Top Speed ? whats that then?
Personally I'd steer clear, there are plenty of tried & tested chips for the V60 out there. Worth waiting or hunting for the SL Carbon chip that is a genuine Aprilia part. It worked superbly in my Falco
F9
F9
My take on this is:
Oh BTW even be careful of brand names you know - I have heard (from someone on AF1) that the Arrow chip is just a copy of the European market standard Eprom.
- * Standard chip is OK - particularly if you've not changed much
* As standard chip is OK, changing chip is not a major priority
* If changing chip you want to be sure that it will give a benefit
* To be sure of benefit you need to choose one where the benefits have been demonstrated (eg FP1413, Gabro, Renegade)
* These may cost more but you know what you are getting .... it's worth waiting and saving for them - IF you really need to change the chip.
* The one on Ebay is very cheap - if it were known to be good, at that price we'd all be buying them and would be well known (unless it's very new and nobody has yet verified it.
Finally, if you plan on making engine/intake/exhaust mods after fitting the chip, you might also consider a Power Commander that allows you to change the fuel map you run.
- mrapriliafalco
let me know when your going to griff's and i'll try and join you.Falken wrote:![]()
Sorry if i'm going off track a little, but e-mailed Griff about setting the throttle bodies a couple of days ago.
He said to make sure the Eprom chip was set to active throttle pots.
Any advice on this, or do I wait till I get down to Griff's place and let him sort it.
