MOT checks - rear reg light
arizonabay
#1 Post by arizonabay » Wed May 05, 2010 9:31 pm
With my tail tidy lost in transit from the German fella, I have decided to fabricate my own (without a reg light).
All the mot test notes/manuals I've checked say nothing specific about a rear registration light - they do however say you need a rear red reflector. Does anyone know for sure if the registration light is definitely required for an MOT pass?
anzacinexile
#2 Post by anzacinexile » Wed May 05, 2010 9:33 pm
Well, the buggers failed mine one year when the bulb failed and I hadn't noticed
#3 Post by Samray » Wed May 05, 2010 9:39 pm
There could be a difference between needing to be working if there is one, and needing to have one. :smt001
#4 Post by Aladinsaneuk » Wed May 05, 2010 10:55 pm
for a full mot you need a plate light
for a daytime only mot you don't
i use the led number plate bolts - about a tenner from evil bay
arizonabay
#5 Post by arizonabay » Thu May 06, 2010 7:52 am
Cheers for the replies.
I just called the mot test centre I have always used and they have confirmed that a number plate light is not required for a full mot pass. :smt003
#6 Post by Aladinsaneuk » Thu May 06, 2010 8:35 am
hmmm
sounds like you have a good test centre - i have failed them in the past for a none working light....
from http://www.ukmot.com/1-1.asp
. With the side and rear lamps switched on, check that the rear registration plate lamp(s) is
(PASS) (FAIL)
a. fitted a. not fitted
b. working b. not working
c. does not flicker when tapped lightly by hand. c. flickers when tapped lightly by hand.
arizonabay
#7 Post by arizonabay » Thu May 06, 2010 9:00 am
Interesting... not sure what is meant by "multiple number plate lamps" - but if the tester is happy, who am I to complain :smt002
#8 Post by joecrx » Thu May 06, 2010 4:51 pm
mine failed for not working 2 years ago , strange , i supose if you have one fitted it has to work ,
tommy
#9 Post by tommy » Thu May 06, 2010 5:19 pm
I've not got one. Went through all MOTs fine
Mr MOT man said its a fail if your light doesn't work, but its not a fail if you don't have one
Isn't there a similar rule regarding spare wheels on cars?
#10 Post by fastasfcuk » Thu May 06, 2010 5:58 pm
tommy wrote:I've not got one. Went through all MOTs fine
no spare wheels do'nt come into it. unless you've got a space saver fitted for the test.
#11 Post by Nooj » Thu May 06, 2010 8:15 pm
Mine doesn't have one and has passed without one for the last two years. Did it change when the new MoT's were bought in?
#12 Post by joecrx » Fri May 07, 2010 9:22 am
im sure its the same with indicators it wont fail if they are not fitted but if they are the would have to work
