Help! fork oil
ReggieGasket
Help! fork oil
#1 Post by ReggieGasket » Tue May 04, 2010 5:57 pm
Hi, is there an easy way to change the fork oil with paddock stands? I can't find any way to jack the bike under the engine. I found instructions on chaning the oil on the internet fromt the USA which said you could drain the oil through the rebound damping plug. That OK?
http://home.comcast.net/~sl_mille/fork.html
Thanks for any help!
Falco9
#2 Post by Falco9 » Tue May 04, 2010 7:37 pm
You cannot change the fork oil on paddock stands unless you have the front one that lifts under the headstock and allows the forks to be dropped
They need to be dropped to change the oil I'm afraid. Can you support the headstock from the garage roof beams at all? I did it that way using ratchet straps and although it looked a bit dodgy it was absolutely fine
F9 :smt006
EDIT. Just looked at the link you posted and to be honest I hadn't thought you would be able to do it that way. I'd have thought that a lot of oil would be still be held above the cartridge, but I may (probably will be) be wrong
ReggieGasket
#3 Post by ReggieGasket » Wed May 05, 2010 6:28 am
Yes, the guy on the link suspended the bike like that. I think it's the only way. I think my garage might fall down, but my father has an RSJ beam. Thanks.
anzacinexile
#4 Post by anzacinexile » Wed May 05, 2010 7:29 am
If you invest in an Abba stand (or similar), the swing arm pivots are pretty close to the point of balance. A simple car jack under the oil tank is perfectly ok as there is very little weight at that point. Just dont try the same with a paddock stand though :smt002
Falco9
#5 Post by Falco9 » Wed May 05, 2010 8:09 am
anzacinexile wrote:If you invest in an Abba stand (or similar), the swing arm pivots are pretty close to the point of balance. A simple car jack under the oil tank is perfectly ok as there is very little weight at that point. Just dont try the same with a paddock stand though :smt002
I wouldn't have thought there was enough room to drop the forks even using an Abba stand is there? (again I could be wrong)
F9 :smt006
#6 Post by D-Rider » Wed May 05, 2010 8:13 am
When I swapped my forks over I did just this - Ulti-pro stand (similar to Abba) at the swing arm pivot and trolley jack underneath the engine somewhere.
F9 :smt006
Plenty of room - wheel out and then you've half the wheel diameter between the forks and the ground.
Falco9
#7 Post by Falco9 » Wed May 05, 2010 8:17 am
D-Rider wrote: Plenty of room - wheel out and then you've half the wheel diameter between the forks and the ground.
I stand corrected :smt018
F9 :smt006
ReggieGasket
#8 Post by ReggieGasket » Fri May 07, 2010 7:37 am
Thanks everyone. The guy on the link doesn't actually drop the forks out all the way. I may as well as am changing the wheels.
