Falco sidestand mod
Falco sidestand mod
Ok we all know the Falco sidestand ain't the best... and people replace them with aftermarket ones... but I've had a quick search on eBay and found this Click me.
Has anyone gone down this route? Does the sidestand switch still work?
Ta muchly!
Ta muchly!
- Falcoholic
- Falcopops
Hey Rick, Grats on the new bike.
I've used a tilter plate and they're OK, but not great, the stand's made of camembert and more tilt made it easier to bend when the gorila on the ferry to Ireland ratchetd it down
Still for no money (if if doesn't go too high) it might be worth a punt 'till you get a better replacement.
USA ones are best
USA ones are best
usa spec or appropriate fireblade model or bubseywoo one off ebay
those are easiest to fit (remember Mr angle grinder will need to play with the usa one)
I used to use the firestorm derived one.... was ok :)
Not the best of pics in the advert but I think that's probably a "Perky's" tilter plate.
I've heard mixed reports - they tip the bike over further but as they don't lengthen the sidestand they don't make it much more stable .... it tips over the other way.
It also doesn't make the stand any stronger ... and remember, the stand is made of cheese.
Probably better to go for:
- A USA market stand and bracket (bracket needs to be modified to fit)
Fireblade stand - apparently bolts straight on ... but I'm not sure how good as I've not seen this mod
One of the Ebay Bubseywoo things (by accounts they've been improved (some of the early ones had welds that failed)
or Gixer stand ... which takes a bit of work but is excellent.
- It's fairly weak
It stands the bike too upright
it's footprint is too narrow (ie it touches down too close to the axis of the bike)
I have a perky's stand adapter....And before i go on, the one you have linked to us does not have a spring pin welded on so it is usless unless you are good with a welder.
As for perkys adapter. I had to cut my stand and fit a length of tube to extend it by 2 inches. It has been fine in all the time i was using it
- exupmonkey
- Track Day Addict
I used a perkys tilter for a while, much better than the OE but it still did not fill me with confidence. I found it more prone to wobbling when on the stand and,because of the altered angles, the foot of the sidestand was no longer flat to the floor but it was only its heel that made contact. On a hot day this would easily sink into the tar becaus the weight was being concentrated on such a small area. As Andy the Holic says...VTR is the way to go!
- DavShill
I also used the tilter for a while. It is a slight improvement but still does not inspire confidence. I went the VTR route. Very easy swop with only a minor job to do to drill a small hole to relocate the cut out switch pin.
Note - it must be the VTR 1000 not the VTR SP1/2. These buggers are exactly the same as the Falco stand - I made that mistake and it's still under the workbench in the garage.
- Willopotomas
The VTR 1000 like this one (AJ sent me the link):
http://cgi.ebay.co.uk/Honda-VTR-1000-Fi ... _589wt_682
