ReggieGasket
#1
by ReggieGasket » Thu Mar 04, 2010 6:55 pm
I've joined the leaky clutch club. I've seen the link about buying a seal. Does anyone have the instructions for doing the job or should I use the PDF workshop manual?
#2
by D-Rider » Thu Mar 04, 2010 8:18 pm
From what I remember it was all fairly obvious and straightforward ... though bleeding the thing when you've done it can be a PITA.
I'd recommend you invest in a banjo bolt with a bleed nipple to attach at the master cylinder and also follow kzmille's guide to bleeding.
https://www.ridersite.com/viewtopic.php?t=3763
Dusty
#3
by Dusty » Thu Mar 04, 2010 8:27 pm
I changed mine and it was a very simple job. Bleeding was dead easy too.
#4
by Fausto » Fri Mar 05, 2010 11:41 am
Ditto
ReggieGasket
#5
by ReggieGasket » Fri Mar 05, 2010 9:03 pm
Thanks. Where actually is the seal that leaks? SOrry never had a hydraulic clutch before
#6
by D-Rider » Fri Mar 05, 2010 9:55 pm
ReggieGasket wrote:Thanks. Where actually is the seal that leaks? SOrry never had a hydraulic clutch before
In the slave cylinder - on the LHS of the crankcase - just in front of the final drive sprocket.
ReggieGasket
#7
by ReggieGasket » Sat Mar 06, 2010 12:46 pm
Thanks. I see from the Workshop Manual there is a small cylinder with a piston inside it. They don't use the term slave cylinder, but I guess that must be it. Does the seal make the barrier between this and the crankcase then? Will get out in the garage and have a look when it warms up a bit!
IsleFalco
#8
by IsleFalco » Sat Mar 06, 2010 3:02 pm
My advice is to dispense with the OE unit and invest in an MPL one. Makes the clutch operation appreciably lighter.
Bleeding was an issue with me, even with a bleeding kit. I am not sure where the air hides, buit it is a bugger to get out. Not a difficult job though - I did it.
#9
by joecrx » Sat Mar 06, 2010 6:12 pm
i did not have any problems bleeding mine when i changed to the mpl , but i did have to have my clutch lever set to full through to compinsate for the extra volume of fluid you need for the bigger slave , it does not work well on any other setting
GRFalco
- Track Day Addict
#10
by GRFalco » Mon Mar 08, 2010 12:33 pm
Me too, it would appear.
GRFalco
- Track Day Addict
#11
by GRFalco » Tue Mar 09, 2010 11:21 am
Seastar reckon they can't get the seal and need a new cylinder, is this true??????
Edit: b'stards. I found one on ebau for 12 quid and maxmoto are selling them for 11 quid.
Grrrrrrr!!!!!
#12
by D-Rider » Tue Mar 09, 2010 11:46 am
GRFalco wrote:Seastar reckon they can't get the seal and need a new cylinder, is this true??????
Grrrrrrr!!!!!
... or you could look in our Aprilia Technical section and buy the one we have found at the princely sum of £2.10 ...............
Here's a link:
https://www.ridersite.com/viewtopic.php?t=4982
GRFalco
- Track Day Addict
#13
by GRFalco » Tue Mar 09, 2010 11:57 am
That's even better thanks!!!!
