Ignition/Immobiliser problem = dead bike
hornetrider
#1 Post by hornetrider » Sun Feb 21, 2010 1:51 pm
Hmmm. Went to awake my bike from its winter slumber today. It appears my trickle charger has died a death sometime in the last couple of months, hence bike had a totally flat battery, doh.
Still, no matter I'll jump it from the car. So, I went to jump it and I have the following problem.
When hooking up the battery to my car the alarm came on as expected - so deactivated with the plipper. All good so far.
Turn on ignition - all dash lights come on as expected - all good so far.
Thumb starter - nothing. Check kill switch and gear lever - in neutral (dash also says so) so no problems there.
Then the alarm auto alarms despite the key being in the ignition and in position 1 with dash on etc.
Also, when the alarm is 'armed' I can turn on the ignition and the alarm doesn't activate - not normal behaviour.
It seems somehow the alarm doesn't realise the ignition is on and is somehow remaining immobilised... possibly?
Anyone got any ideas?
#2 Post by D-Rider » Sun Feb 21, 2010 2:31 pm
Not saying I can help but maybe we can get somewhere if we know what alarm you've got on there.
hornetrider
#3 Post by hornetrider » Sun Feb 21, 2010 2:43 pm
Haven't we all got Datashite System III?! :smt010
#4 Post by D-Rider » Sun Feb 21, 2010 3:47 pm
hornetrider wrote:Haven't we all got Datashite System III?! :smt010
No - thank God!
(I've got a Meta)
Guess you have though - this wouldn't be the first time we've come across starting problems with Datatool.
#5 Post by joecrx » Sun Feb 21, 2010 7:16 pm
i have a datatool alarm . once it fell down i pressed the 2 buttons to gether listen to tone then the right listens for tone press right listen for tone and turn off ignition and start again this should bring it out of sleep mode
hornetrider
#6 Post by hornetrider » Sun Feb 21, 2010 10:31 pm
Can you run that by me again Joe :smt042
#7 Post by D-Rider » Sun Feb 21, 2010 10:55 pm
I think joe's suggesting:
  • * Press both buttons together
    * Alarm will beep
    * Once it has beeped: Press the right button
    * Alarm will beep
    * Once it has beeped: Press the right button again
    * Alarm will beep
    * Turn off ignition
    * Turn on ignition and (hopefully) it will all start up normally
Joe, have I followed this correctly?
That said, this is what the Datatool System 3 user guide says:
Also from the User Guide:
From Datatool FAQ:
Datatool Info:
#8 Post by Aladinsaneuk » Sun Feb 21, 2010 11:00 pm
if it is the same alarm that hanna has - and your indicators are flashing constantly, then...
use the plipper, put keys in and turn ignition on
within 5 seconds hold plipper down for 3 seconds - it should cirp
then try it
if that does not work let us know - may be able to let you have a phone number of a chap... and a few web addresses to identify the alarm....
hornetrider
#9 Post by hornetrider » Mon Feb 22, 2010 12:13 am
Superb guys cheers for all that - I'll let you know how I get on in the morning :smt001
#10 Post by Aladinsaneuk » Mon Feb 22, 2010 8:33 am
oh - and jadaris alarm fob has only one central button - i am hoping that as both bikes are on the same batch then.....
if so, then i think you will find the alam is a 375t
http://abacuscaralarms.co.uk/members/fo ... owforum=19 may be of help
finally i called a chap on 07640018881 who was very helpful
(let me know if i have given you the wrong number!)
#11 Post by D-Rider » Mon Feb 22, 2010 8:52 am
Aladinsaneuk wrote:oh - and jadaris alarm fob has only one central button - i am hoping that as both bikes are on the same batch then.....
Pete, you donkey, the 375-T is a Meta alarm ...... Hornetrider has a Datatool System 3 .......
The batch of bikes has nothing to do with it ether .... alarms are not standard fitment.
:smt009 ........ care in the community ....... :smt009
hornetrider
#12 Post by hornetrider » Mon Feb 22, 2010 9:13 am
:smt043
Yes, mine is a Datatool with two buttons :smt002
#13 Post by Aladinsaneuk » Mon Feb 22, 2010 9:49 am
mutters -
hornetrider
#14 Post by hornetrider » Mon Feb 22, 2010 12:41 pm
Ah ffs why is nothing ever effing easy?? :smt013
I'm following the instructions to despike.
1. Remove lid from main alarm unit. - Check
2. Remove internal battery link from PCB (arrowed) - Check
3. Remove alarm inline fuse - Check
4. Unplug PCB from alarm loom - You're having a f***ing laugh Mr Datatool :smt014
Trying to completely unplug the loom when some nugget has poured in some liquid rubber gunk to hold all the wires place is an impossibility! Also the wires are too short so everything is too bloody tight, argh! :smt018
So, I've managed to remove 3 of the plugs and hope that will do the job. Have to leave it for 6 hours now.
Bastids :smt005
#15 Post by Nooj » Mon Feb 22, 2010 1:16 pm
I'm sooooooo glad I don't have an alarm :smt003
