2 quick questions on front sprocket change
I've decided to put a 15T sprocket in:
- does the sprocket bolt have a standard or a "reverse" thread?
- threadlock - what do you use? I've got some Locktite 222, but maybe I could source something else from work.
Thanks
Thanks
Just been checking, and while Loctite 222 is certainly better than nothing, I think Loctite 243 might be better suited. This is the blurb:
Loctite 243 Threadlocker 10ml
A removable strength, general-purpose threadlocking adhesive especially well suited for fasteners between 1/4" and 3/4" diameter. Tolerant of oil and other contamination. Protects threads from rust and corrosion. Cures reliably even on stainless steel. Available Worldwide
Specifications:
Machine tools, presses, pumps, compressors, mounting bolts, gearboxes.
NSF/ANSI 61
24078
I must admit seeing the word 'gearboxes' encouraged me...
Specifications:
NSF/ANSI 61
24078
- Falco9
Loctite 243 is the one to use. Aprilia actually state it must be used in their workshop manuals.
Don't over tighten the bolt, they have a habit of the head shearing off, just the std 50nm torque is fine.
The bolt is std right hand thread so should self tighten on itself as the sprocket turns, but as Andy has mentioned a few have come loose with nasty consequences
The sprocket bolt on my brand new Tuono was only in finger tight, so its worth checking the bolt every now and then
F9
F9
