What not to do with a full tank
#1 Post by Fausto » Mon Feb 19, 2007 6:25 pm
Ah - you're ahead of me already aren't you :smt009
Was looking into the sticky throttle issue (now sorted) and raised the tank to check the cables. Noticed a rather strong smell of petrol and an interesting "peeing" sound. What's that pouring out of the bottom of the bike??
I didn't react immediately as there is often a small discharge from the filler cap overflow pipe when I tip up the tank. Water usually. This time though it was a full on flood of liquid gold pouring onto the carpet. (yes she does sleep on a carpet)
I guess the spring on the filler cap isn't all that strong. :smt009
#2 Post by Nooj » Mon Feb 19, 2007 6:28 pm
Too late now, but always put a clean jam jar or similer under the rubber pipes when you lift the tank. Any thing that comes out can go gack in when the tank is back down. ( I usually forget though).
Thumper
#3 Post by Thumper » Mon Feb 19, 2007 7:30 pm
You need to be careful not to raise the tank to much as the fuel pipe can snag at the pump end and come adrift a certain owner I know did this whilst smoking :smt073
