Any ideas where to look ?
Oh and belated Xmas wishes everyone and a happy new year
OK - update - I've had a look at the wiring diagram:D-Rider wrote:Hi Yellowasp ..... If I were you, I'd try a different tack when the snow thaws.
It won't be a broken pin on the sidestand switch for 2 reasons:There are actually 2 distinct circuits that are controlled by the sidestand switch - one is the warning light, the other is the interlock that stops the engine running if it's in gear with the sidestand down.
- 1) The bike is starting OK - therefore the switch is working.
2) Your bike is a later model that has a sidestand switch with a metal pin (not the fragile plastic type)
I suspect you have a wiring fault in the warning light circuit - or, less likely, the a problem with the part of the switch that controls this circuit.
OK places I've been for tyres are:yellowasp wrote:aye , mine has a belly pan so will check that first as i am doing oil and filter change this weekend . D Rider , do you know anywhere around Cov that change a supplied rear tyre without stealing my wallet ? 25 pounds they want
Bikers World was one who wanted £25 to do it. I will try James as he as the same name as me so can't be all badD-Rider wrote:OK places I've been for tyres are:yellowasp wrote:aye , mine has a belly pan so will check that first as i am doing oil and filter change this weekend . D Rider , do you know anywhere around Cov that change a supplied rear tyre without stealing my wallet ? 25 pounds they want
Robsom RacingBikers World @ Daventry
- #B Brailes Industrial Estate, Brailes Road, Shipston on Stour, Warwickshire CV36 5AD
Tel: 01608-664122
It's a bit of a way from Cov but Mike is usually pretty competitive for tyres and fitting .... and a nice chap too.... and one I've never used so far but many of those on the Coventry Bikers Forum strongly recommend:
- 2 Browns Road
Daventry
Northamptonshire
NN11 4NS
Tel : 01327 312 724
http://www.bikersworldshops.co.uk/uk/shops/daventry/
Bikers World also have a place in Birmingham - consensus is the staff at Daventry are good and helpful ... in marked contrast to those at Birmingham
James (Burgerbiter on the forum)Not sure how keen Robsom Racing and Bikers World are at changing a supplied tyre (probably OK) but I know that James will definitely do it.
- He's somewhere off the A45 near Wing Wah
He can be contacted on this number: 07786071898
I've not met him but I'm pretty sure that he'll know how you found him if you mention D-Rider put you in touch.
He used to have an 02 RSVR BTW.
Hope this helps
