I'm not being lazy and I really have searched, both here and AF1 but I can't find any info regarding the size of the rear dogbone bearings.
I've obtained an RSV dogbone and plates to go with a shock I've had for a while.
When I checked the needle rollers they were so badly rusted I decided I was going to replace them.
Now it's been my experience that it's a lot cheaper to source replacements at a bearing suppliers than buy at dealer prices.
Trouble is they were that knackered I've had to virtually cut them out so I haven't got a whole one to compare.
Anyone actually know the correct size/code for the bearings?
Rear linkage needle rollers
Do you know if they're the same as those on a Futura? If so, I've got a spare linkage with the bearings, which I'll gladly measure for you.
Or give Griff a ring at Aprilia Performance : www.apriliaperformance.co.uk 01827 285500
Re: Rear linkage needle rollers
Chabby wrote:I'm not being lazy and I really have searched, both here and AF1 but I can't find any info regarding the size of the rear dogbone bearings.
Try the STICKY thread in the Aprilia Technical section entitled
"Swingarm, Suspension Linkage, Wheel & Steering Bearings"
I think you'll find everything you need to know there.
