Oli
A set of Brembo original wheels (I’m happy to split them if someone only wants front or back). The paint on them is ok, on the rear disc mounts it’s flaked off and one or two chips but no damage to the actual rims. £100
A set of original Brembo front disc's. Loads of use left in these, all the bobbins have been loosened up as well!!!! £45
Rear brake disc, still plenty of life in it - £15
Rear JT steel Sprocket 41T, it's done about 4k miles £10
