Rear wheel removal - 22 mm hex bit socket
Tried Halfords - nothing on their web-site or in store (don't need one, but thought I'd ask while I was there)
The one on the link looks like an impact socket - probably OTT for our needs, and yes, a bit pricey, but if someone needs one PDQ . . .
Also came across this (yes, I've had such a busy Sunday afternoon). Looks to be better value?
http://cgi.ebay.co.uk/NEW-METRIC-ALLEN- ... 286.c0.m14
Both these options are cheaper then a decent quality 22 mm. hex key, which you'd have to butcher anyway
Yeah this has had me very confused too - maybe the Futurama has different spindles - the Falco certainly doesn't use hex keysFalcopops wrote:Not even sure you need one of these.
Once the spindle clamp bolts are undone the spindle pushes out easy.
Nothing to do with spindles - s/s swinging arm
It's for undoing the rear wheel retaining nut - No. 10 on the drawing. There's a stubby bit of 22 mm hex bar in the toolkit, but they seem to have a habit of getting lost as Futuras change hands.
Good pointFalcopops wrote:(still not sure if that's the right emoticon)
I see, my apologies for being futurilliterate.
Might be worth grabbing a 14mm one at the same time for the steering top clamp nut while you're at it.
