Angled Tyre Valves.
- bluedimension
Angled Tyre Valves.
I am looking to fit angled tyre valves to my beast. My local Ducati dealer (Parkinsons) wants £20 for a pair. They look good quality but haven't arrived yet.
For those of you who have fitted/used them which brand did you go for and are there any pitfalls I should be aware of.
I was warned off the cheap (£1.99) rubber seal ones that are commonly advertized and although I have used a right angled adaptor it tends to let air out when removed.
Why don't they fit them at the factory is what I want to know?
Cost, I guess. I notice that M&P do the Ariete 80degree angled valves for £15.99, but after you've added P&P on... I've got them fitted to my Falco and they're great. Pumping up your tyres is now a simple, 30 second, stress-free job.
If you're fitting them to your bike, make sure the outlet is pointed towards the off-side (RH) of the bike. Then when the bike's on its side stand it's a doddle to check and inflate your tyres.
Yeah I bought a pair of ducati ones and I have one of them on the front - makes things Sooo much easier.
BUT
Had some problem in sealing them to the rim .... which is why I don't have one on the rear wheel as in sorting it out, my tyre firrer crossed the thread on my angled one!
Now I don't know if this sealing to the rim problem is something that applies to the standard Brembo wheels or just the Oz wheels. The Oz wheels have a bit of a ridge down the centre that the standard o-ring doesn't take up fully.
Anyway my verdict is that fitting them is certainly worth the effort .... and one day I'll get one on the rear wheel too - as well as a set on my winter-use Brembo wheels.
BUT
Just so that nobody is misled ......
The Ducati ones do fit the holes.
Aladinsaneuk wrote:need the italian size - i believe the riceburner valve holes are 7mm, eyetie flavour is 8mm?
Pete's general point is right though - the valves do come in different diameters and you do need to get the right size.Aladinsaneuk on the AF1 forum wrote: I also replied on ridersite - am sorry but the valve sizes i quoted was wrong there
- bluedimension
