Horn not working
Horn not working
Hi all.
Just noticed my horn isn't working. When pressing the button I only get a short beep/clunk sound. Sometimes it works for a few seconds but goes back to dead after.
Are the known to fail? Is this fixable or should I be looking for a new one?
Found some rsv one on ebay, but how do I get the old bugger out?
dyzio
dyzio
- Firestarter
- Twisted Firestarter
Had to replace the horn unit a year ago for MOT, after fiddling with the switches and finding they were OK I eventually found the horn, just ran some leads direct from the battery across it and it was dead. I think, cos of where it is, it can get crapped up and can fail.
It could be one of a number of things but this thread i posted in the Aprilia technical section could be of help to you:
https://www.ridersite.com/viewtopic.ph ... light=horn
If it happens to be the horn itself, I do have a spare that works.
- Firestarter
You need to remove numbers 5 & 6 below
http://www.apriliagenuineparts.co.uk/co ... d-1260.php
and if it is a wiring problem, you need to remove the right hand fairing panel.
Dave
Better to remain silent and be thought a fool, than to open your mouth and remove all doubt.
That would be my suggestion, too, going on experience with some of my earlier bikes. But I don't know how well protected your horn is.Firestarter wrote: I think, cos of where it is, it can get crapped up and can fail.
If you have to replace it, take a look at this one - not too pricey, loud (108 db) and, being for marine use, could be more durable. I've just bought one, but haven't fitted it yet http://www.marinemegastore.com/product. ... =0&cat_id=
Also in stainless : http://www.marinemegastore.com/product. ... =0&cat_id=
Don't be tempted by the Stebel Nautilus - some reliability issues, apparently : http://www.advrider.com/forums/showthread.php?t=128816
Re: Horn not working
Have you tried Viagra?dyzio wrote:Hi all.
Just noticed my horn isn't working. dyzio
sorry - someone had to say it
Actually I'm surprised it took so long :DMartDude wrote: sorry - someone had to say it
Took the switch apart, shorted the pins out - the same.
Took the bugger out, tried on a battery, the same thing.
Ebay, here I come.
dyzio
