Washers for oil change
- ReggieGasket
Hi, does you know where I can get washers for both of the oil plugs? Sorry for the mundane question
- ReggieGasket
Re: Washers for oil change
Well, unless they are knackered, use the old ones.ReggieGasket wrote:Hi, does you know where I can get washers for both of the oil plugs? Sorry for the mundane question
Can't remember for sure what I did - although I've I've usually some washers lying around, inevitably I don't always have the right size or ones of the right material to replace them.
Think one of them was an aluminium washer that I filed the surface flat before putting it back.
Alternatively, if you haven't removed them yet, don't know exactly what they are and want to have some ready for when you do this, your local, friendly Aprilia dealer will sell you the official ones ... at a price.
For part numbers (or even to buy them), look here:
http://www.ultimateparts.net/
As for the Scottoil, there are 2 varieties designed for 2 temperature ranges. I've always used the Blue stuff - think the Red is for warmer places (Scottoil's website will confirm).
I fitted my Scottoiler several years ago and have only just used up my first bottle of oil - running costs are low - no point in sourcing a cheap oil IMHO.
- ReggieGasket
Thanks. I've got a leak from the plug next to the oil filter. I did notice the brass washer was a bit knackered when I changed the oil. Here's a question for you - how much oil will come out if I just remove that oil plug? I guess I could do it quickly and put a finger over the hole while I swap the washer. I've just changed the oil you see...
.... or you could catch it in a jug and pour it back in when you've sorted it - which I guess is what you're planning.ReggieGasket wrote:Thanks. I've got a leak from the plug next to the oil filter. I did notice the brass washer was a bit knackered when I changed the oil. Here's a question for you - how much oil will come out if I just remove that oil plug? I guess I could do it quickly and put a finger over the hole while I swap the washer. I've just changed the oil you see...
Not sure how much of it will come out - so assume you need a jug or bowl big enough for the lot (almost 4 litres)
- Falco9
Thats exactly what I would do, whatever comes out catch it in a container and pour it back in. But to be honest I've never replaced the washers and I have never had a leak either on the Falco or the TuonoReggieGasket wrote:Thanks. I've got a leak from the plug next to the oil filter. I did notice the brass washer was a bit knackered when I changed the oil. Here's a question for you - how much oil will come out if I just remove that oil plug? I guess I could do it quickly and put a finger over the hole while I swap the washer. I've just changed the oil you see...
F9
Clean the washer really well before reannealing then do what Pop says, although doing it too many times will cause it to become brittle and cause it to not be effective 'coz it wont squish properly', so maybe only do it once or twice before renewing the washer.
Aluminium, you can reanneal, although it doesnt have to be that hot or youll end up with a blob instead of a washer. Again, clean it up well before you heat it up, etc
I knew the months spent in metallurgy lessons during my apprenticeship would be of use sometime..
Thankyou taxpayers..
You bunch of tight-arses! How much does a new washer cost? Get a new one, have peace of mind, then fanny about re-annealing the old ones for spares.
Anybody would think you lot were from Yorkshire
like me
like me
- Falcopops
30p! d'you think I'm made of money, bloody daylight robbery.Chabby wrote:MartDude wrote:You bunch of tight-arses! How much does a new washer cost? Get a new one, have peace of mind, then fanny about re-annealing the old ones for spares.
like meHe's got a point. I bought a compatible one at my local dealers for 30p!
I remember when I was a lad.......mutter.............mumble
