front wheel removal
scorpio24v
front wheel removal
#1 Post by scorpio24v » Tue Sep 01, 2009 5:13 pm
Time has come for new rubber I have sourced a pair of Roadsmarts for £150 but i have to take the loose wheels to the fitter. I have an abba stand so getting the rear outs a doddle but how do you lift the front to get the front wheel out? I am not happy in putting a trolly jack under the exhausts and there isnt a suitable jacking point on the crankcases, I havnt got a roof truss in my garage to suspend the front from so how do you do it?
"Aprilia is brilliant at combining Italian panache with Japanese-esque reliability and build quality. It's like dating a porn queen, except when you take her home she puts her hair up in a bun, dons her glasses and does your tax returns for you.”
#2 Post by HisNibbs » Tue Sep 01, 2009 8:16 pm
I have a stand that mounts at the swing arm pivot and the bike is nearly balnced about that point, so I press onto the seat grab rails to get it on the back wheel then place (kick....) a wooden block under the oil tank to stop the possibility of it tipping forward.
Thumper
#3 Post by Thumper » Tue Sep 01, 2009 9:19 pm
If you have a rear stand and a car trolley jack you can jack under the oil tank it fits a trolley jack cup just right :smt001
You are not lifting the hole bike just supporting the front end.
It's best to b put a suitable piece of rubber mat or carpet underlay between the cup and tank though. I also zip tied the rear stand pegs for safe measure. Used this method for over 7 years working on my falco with no ill effects.
I have an abba stand but found it tiresome to use except when lifting out the swing arm or shock then its very usefully :smt004
Always expect the unexpected
Firestarter
Twisted Firestarter
#4 Post by Firestarter » Wed Sep 02, 2009 7:44 am
Maybe not the answer you want, I just use rear & front paddock stands, lifts both wheels clear and is pretty stable. Like you, I wasn't keen on putting something under the exhausts, or something slipping (kids + pushbikes in garage + suspended bike = damaged kids + damaged bike)
If you've got a rear stand already, a front is about £20-£30 iirc, or you often seen deals on Busters, M&P, for front & rear stands
wavey
#5 Post by wavey » Wed Sep 02, 2009 9:05 am
Hi, I use an Abba Stand and used to use a scissor jack under the oil tank, it was stable enough but I didn't like putting pressure on the oil tank, so I borrowed my brothers front stand and forgot to give it back :smt002
Dave
Better to remain silent and be thought a fool, than to open your mouth and remove all doubt.
scorpio24v
#6 Post by scorpio24v » Wed Sep 02, 2009 9:39 am
Thanks Thumper, I`ve got a trolley jack and have used it as suggested. Cheers.
Vince
scorpio24v
#7 Post by scorpio24v » Wed Sep 02, 2009 3:21 pm
I think i may have found another difference in the later Falco`s with the Marzocchi forks. The front axle nut is a 30mm jobbie not a 28mm as elswhere on the forum suggests.
#8 Post by D-Rider » Wed Sep 02, 2009 3:51 pm
Online parts catalogue just lists the one part for all years.
http://www.ultimateparts.net/shop/part. ... -AP8152335
I thought it was 30mm front, 32mm rear.
Maybe we've typed up incorrectly on a previous occasion (may be me? maybe doing it from memory and got it wrong?)
Maybe they are different
EDIT: Just done a search and found some numptie called D-Rider did post up that they were 28mm ..... very sorry
:smt053
Aladinsaneuk will have a field day at this
Please give generously to the Alzheimers Society
scorpio24v
#9 Post by scorpio24v » Wed Sep 02, 2009 9:42 pm
Happy Easter D-Rider:smt002
#10 Post by D-Rider » Thu Sep 03, 2009 12:18 am
Have they brought me my dinner yet ?
Midnight Rider
#11 Post by Dalemac » Thu Sep 03, 2009 4:06 am
Id be asking for more than that :smt003 :smt003
