- * Cleaned ad greased the clutch lever pivot
* Cleaned and greased rider and pillion footrest pivots (and even found each of the pillion footrest ball-bearings that I dropped)
* Greased the pillion seat catch
* Did my annual clean of the brake rotor bobbins
* Adjusted the chain
* Sorted out the fuel filler water drain that wasn't draining properly
Then when it looked as though the showers might be finally over I set about the hydraulics.
* Fitted the new clutch master cylinder banjo bolt with a bleed nipple
* Changed the clutch fluid and bled the clutch (that new bleed nipple makes a huge difference)
* Changed the front brake fluid - using the right calliper bleed nipple.
Then the fun came ......
* Tried to flush through the new fluid to the front left calliper .... damn that nipple is tight ..... bit of easing fluid on it and wait a bit ..... try again ..... no luck ... bit more easing fluid .... put the ring-end of my best spanner set on the bleed nipple and give a good tap with a hammer (to give a bit of shock) .... nope .... heave on the spanner .... and it spins on the hexagon which has now become a new geometric shape with rounded corners.
Bugger.
Mole grips wouldn't budge it.
* So I gave up and did the rear brake (again the nipple was hard to move but I managed to sort it without damage .... guess the slightly bigger hexagon on the rear may have helped.
Obviously I'm going to have to replace the bleed nipple
Anyone got any tips on how remove the old one with the minimum of fuss / risk of damage.
