evolutione tail tidy
- mrapriliafalco
Does anyone have a clue where this can be bought now RSVR.NET has closed !!!!!!!!!!!
Evoluzione list their dealers on their website. 3 are shown in the UK - one of which was RSVR but there are 2 others to try:
http://www.evoluzione.net/evo-cycle-aprilia.htm
Alternatively you could make your own - there's a drawing of a diy one on the forum ..... if I can find the link ....
EDIT:
It was posted up by Falcomunky in this thread:
https://www.ridersite.com/viewtopic.ph ... y&start=15
Here are some of the pics:
There was another diy design on (the now defunct) C-Plus' site. I've a pdf of that if you are interested - just PM me your e-mail address and I'll send it to you.
EDIT:
Take a look at the link
http://cgi.ebay.co.uk/Kennzeichenhalter ... 911.c0.m14
I have just ordered one. Made an offer of 23 euro that was accepted. Looks pretty good for the price. I'll update when it arrives and its fitted.
- mrapriliafalco
Please post a pic when finished, im curious too.blenks wrote:Take a look at the link
- ReggieGasket
- mrapriliafalco
Are you talking about the big scottoiler touring tank that's designed to go behind the number plate or just the normal cylindrical reservoir?mrapriliafalco wrote:Im up for that,only worry I have is my new Falco(my 3rd) has had a scott oiler fitted and sits behind the number plate.
Does anyone know where it can be moved too.
If it's the latter there are loads of places (mine's under the rider's seat above the battery). If it's the big tank ..... not sure .....
- Falcopops
mangocrazy wrote:It sounds like mrapriliafalco's Falco has the touring high-capacity reservoir fitted. The only option I'm aware of is to fit the LubeTube (a Scottoiler add-on) in place of it. This is much more flexible (quite literally) in placement; mine fits round the edges of the pillion under-seat area.
Hopefully the photo's will work.
OK, fitted the tail tidy today. Firstly removed all of the original hardware, plate, carrier, indicators etc. Then offered the bracket to the undertray, marked and drilled the holes. (the holes in the bracket line up with the original metal carrier) but I chose to fix to the undertray as it made it higher.
Removed the number plate light. I had to redrill the holes in the bracket as they did not line up. Easy enough. Then fitted the original number plate light to the plate holder.
Fitted new small indicators. I used bullet connectors crimped to the leads. The number plate light lead connector would not fit through the hole I drilled in the bracket (the largest drill I had) so I cutt the wires, fed them through and reconnected using bullet connectors again.
The angle of the plate holder can be adjusted and to get the angle I wanted I had to lengthen the indicator leads.
Hope this helps. The tail tidy is pretty good quality really for the price. Easy to fit with minimal modification to fit it the way I have. I think it looks much better especially without those huge indicators. There is also a bracket to fit a reflector to but I have'nt bothered with that. Let me know if you need any other info.
