Evoluzione Clutch Slave
- exupmonkey
- Track Day Addict
Hi all, won one of these on the bay last night, sorry if I gazzumpt anyone here but needs must as I am losing fluid. Anything to look out for when fitting it, better still, anyone got an idiots guide cause I'm a dobber with a spanner
Physically fitting it is a piece of cake - undo the bolts - remove the old one - pull the spacer of it - pop the spacer on the mpl slave and bolt it up.
The fun begins when you start bleeding the clutch fluid.
Use Kzmille's guide https://www.ridersite.com/viewtopic.php?t=3763 and reverse bleed.
Fitting one of these at the master cylinder end will help the bleeding too.
http://www.rsvr.net/products/product-55 ... leeder.htm
Oh yes - clutch fluid - Dot 4 (or Dot 5.1) BUT NOT Dot 5
I've not long fitted one, dead easy if you don't put the spacer on back to front (which, of course, I didn't
Bleeding easy - sorry, the bleeding was easy, big syringe on the banjo bolt thing, suck out the old & squirt in the new.
Dave
Better to remain silent and be thought a fool, than to open your mouth and remove all doubt.
- exupmonkey
- Track Day Addict
- Falcoholic
Re: Evoluzione Clutch Slave
Least ya got that right.exupmonkey wrote:I'm a dobber![]()
The Delicate Sound of Thunder
- exupmonkey
- Track Day Addict
- Falcoholic
