So I propose a suspension day. I need at least 2 forum members and myself to set up the suspension. In return you also get your suspension set up. All setting will be recorded ie original, max rebound and compression, min rebound and compression.
Also i will adjust ride height if it is required (if you so require and the shock allows)
The wife will supply the bacon butties and if time allows we could go for a rideout somewhere aswell (although you will need to go for short bursts to check the new settings)
Any bike can come but i am limited to space so bike will be parked out on the front.#
Any takers
