Swingarm bobbins
Swingarm bobbins
Hello guys, need to order some of these, mine doesn't have any and I can't get her up steady using the platforms off my stand.
Can anyone confirm the thread size - I've seen plenty on evilbay which are 6mm thread.....
I want to order a.s.a.p. chain needs a clean, lube & adjust and the back wheel is dirty..!
- bluedimension
Jayboy,
they are indeed 6mm thread. I got some off ebay for a nominal sum. As Fausto rightly explained the "cargo" mounts are dual purpose and serve as bobbins also so if they are still fitted to your machine you could use those. I kept mine in situ and bought some alloy bobbins. In fact I have some nylon ones you can have if you pay the postage. Black nylon ones though not shiney alloy I'm afraid. (PM me)
Blue.
Blue.
