rear caliper
scottyni
rear caliper
#1 Post by scottyni » Wed Jun 10, 2009 12:27 pm
sticky piston which sorted.... then....
pushed the piston in and i put a hole in the face of the piston. little bar i use slipped.
better too get a caliper or replace piston??
any1 have a rear caliper ????
if you can't ride it....
OR take it too bed...
IT AIN'T WORTH HAVIN...
#2 Post by Fausto » Wed Jun 10, 2009 2:34 pm
Wow, never heard of that before.
Is it a Brembo? You can't get many (if any) spares for Brembos so a new Caliper may be the only way. I'd try to replace the piston only though especially if the rest is in good nick.
Syltiz
Chaos Merchant
#3 Post by Syltiz » Wed Jun 10, 2009 2:48 pm
You must be the Irish version of The Incredible Hulk :smt003
#4 Post by D-Rider » Wed Jun 10, 2009 2:59 pm
Sorry, the only one I've got is on my bike.
I know spares for Brembos are hard to find but Mangocrazy did (eventually) uncover a source of the almost-unobtainable seals:
https://www.ridersite.com/viewtopic.ph ... embo+seals (that thread does deliver in the end!)
I'm guessing they may do pistons too.
That said, Ebay usually throws up some callipers.
Also SteveP has been breaking his Falco - maybe he's still got the calliper to sell - worth enquiring (I've had a few bits off of him - he's a pleasure to deal with).
Also, some time ago I remember there was an upgrade calliper that people fitted. Think it was slightly bigger and worked better - search here or the old forum and I think it will tell you.
#5 Post by mangocrazy » Wed Jun 10, 2009 4:10 pm
Hi Scotty,
I think you might be in luck with eBay, as I've normally seen quite a lot of rear Brembo calipers for sale on there (they're not sexy, like front calipers, y'see...)
I'm dead impressed that you could put a hole in a brake piston, btw...
redfalco
#6 Post by redfalco » Wed Jun 10, 2009 5:21 pm
:smt006 You could give www.wemoto.com a try. Ive never used them myself.
scottyni
#7 Post by scottyni » Wed Jun 10, 2009 6:09 pm
i thought the piston was a solid block, noone more surprised than myself.
got a caliper sorted out, pick up tomorrow.
got all the bearings of wemoto just last week quick service if needed by others
cheers for the info guys
bigun
AP RS Legend
#8 Post by bigun » Wed Jun 10, 2009 6:09 pm
Did the same on mine. Never leaked. Went through 2 mots too! I'd just leave it me like.
Bigun
shootmyscoot
#9 Post by shootmyscoot » Thu Jun 11, 2009 8:41 am
rear caliper here and 2 front brembos as well
sms
scottyni
#10 Post by scottyni » Thu Jun 11, 2009 9:24 pm
sourced a caliper over here. many thanks for offer.
this 1 not leaking either, i thought it was a solid block, little do i know.
