Zumo Mounting
Zumo Mounting
Has anyone here fitted a Garmin Zumo to their falco WITHOUT a double bubble screen? Ideally (if I buy one) I would like it fitted centrally whilst still getting a good view of the clocks.
Don't like DB screens, I had one on my ZX6R A1P but it just battered my head if I went over 60/70mph.
Dave
Dave
yes
you can manufacture a mount that will go into the headstock has the gap for the securing pin for the tank bag is
I did that before i fitted the screen under the double bubble
Just the answer I was hoping for, thanks. I had thought of using the tank mount gizmo as I don't use the tank bag much anymore, but I wanted to know that I could still see the clocks ok.
Actually, saying that, I would'nt need to see the speedo 'cos the Zumo has one, and I would'nt need to see the Zumo 'cos I've bluetoothed my lid and it would talk to me (and stop me feeling lonely).
Dave
Dave
- FlyingKiwi
Not really, very little (if any), the nav is touching the screen when fitted, so I guess that helps. I'll find out when I'll be off to EU land with a DB screen.wavey wrote:Thanks for the pics guys, both very neat.
dyzio - do you get much vibration from mounting there? Do you think the larger & heavier zumo would work there?
Dave
Dunno about the zumo, I wouldn't be worried about the weight, but it will most likely obscure the rev counter.
Having said that, I'd try to hold the zumo in the same place I have mine, you'll see how much of the rev counter you can see.
Aye, I can take the screen off, you'll see how it's made. But won't get a chance till tomorrow.Syltiz wrote:Dyzio... could you take another photo showing how hte brackets are mounted? Sorry to be a pain
Not a Zumo I'm afraid, because it was outwith my budget but I fitted a RAM mount on an L bracket fixed with sticky pads onto the "dash" under the screen for my Nuvi250. I used a RAM because I was concerned that the standard Garmin mount may not prevent the unit bouncing out on bumpy roads. It's pretty rigid and extremely easy to see in that position. I did consider using a headstock mount but found that to be too low to glance at without bending my neck. The dash position is in my line of sight.
I used a Telferizer mount http://www.telferizer.com/prods.html#aprilia which fits in the centre of the headstock with my Zumo 400. It fits well and with the short arm does not block the instruments.
95 St. Lesmo Road
Cheadle Heath
Stockport
Cheshire
SK3 0TZ
England
Telphone: 0161 476 5701 (after 6.30pm)
Hope this is of some help.
95 St. Lesmo Road
Cheadle Heath
Stockport
Cheshire
SK3 0TZ
England
Ok, the mounting is made from two "L" brackets and a "T" bracket from B&Q.
One of the brackets was flattened and fits on top of the subframe. I've drilled 2 holes in it and bolted the "T" bracket to it. The second L bracket is attatched to the T one and holds the garmin mounting (M4-or3 bolt + some rubber grommets)
Doesn't look very nice, but hey, it's covered by plastic and does its job perfectly.
Moggyvan - what's the address ?moggyvan wrote:I used a Telferizer mount http://www.telferizer.com/prods.html#aprilia which fits in the centre of the headstock with my Zumo 400. It fits well and with the short arm does not block the instruments.
95 St. Lesmo Road
Cheadle Heath
Stockport
Cheshire
SK3 0TZ
England
If it's yours may I respectfully suggest you remove it asap. You don't want the whole world knowing the location of your pride and joy I should imagine.
