oil light
- scottyni
oil light
2 things...
1. oil light on constant...oil level is plenty.
2 oil light ONLY on when the bike ticking over, blip the throttle and it goes out!!!
what is wrong????
cheers in advance
scotty
what is wrong????
cheers in advance
scotty
if you can't ride it....
OR take it too bed...
IT AIN'T WORTH HAVIN...
- Falcopops
The light is linked to a pressure sensor, which is related to the oil level, but not solely. Clearly if there ins't enough oil in the system the pressure can't rise enough to trigger the sensor.
Since you've got plenty oil and the light goes off with a blip I'd suspect a failing sensor, but I'd be tempted to check the wiring 1st and check the filters like D-Rider says.
I think that it is more likely that the sensor is faulty than the oil pressure is low. So replace and clean filters and if not resolved, swap out or replace the sensor asap. Fail safe wiring on the sensor probably has the light stay on if it is broken. If that doesn't work then I think its check the oil pump next...
- BikerGran
- Gran Turismo
Think I'd check the pump right away - you can have plenty oil in the sump but if it's not getting where it needs to be that could get expensive!
A sensor surely usually works or it doesn't - and the fact that blipping the throttle makes the light go out shows that the sensor IS working and telling you that the pressure not the quantity is wrong!
- scottyni
today on way too work i had no light then light on constant.
watched as i started up and oil drained but after starting later it did not drain from the tube.
that i think is a problem with the pump???
not what i need as i'm spending on the falco getting that ready for the road, bloody aprilia
No, they do that from what I remember - it's something to do with the position the oil pump stops - so different times you see a different thing - hence the rather complicated procedure for checking the oil level.
I'm not saying your pump is certainly OK but it's too soon to conclude it isn't.
- scottyni
new oil 15 50 and filter. light came back on once engine heated up.
where is the sensor i'm looking for?? down brake side on the engine?? then leads to a connector??
will the falco one fit?? where on the falco??
i have the parts breakdown but i cant find which section it located??
many thanks for above posts
