Stop/Tail bulbs - parallel (opposing) or offset pins?
TwinNut
#1 Post by TwinNut » Thu May 28, 2009 12:36 pm
Tweaker
Main bike: BMW R1250RS
#2 Post by Tweaker » Thu May 28, 2009 12:59 pm
They're offset pins (AFAIK all the twin fillament 5/21w bulbs are). From what I remember, the standard bulb fits through the hole with only a mill or two clearance. If you measure a standard bulb and use that as the reference, you'll be fine.
TwinNut
#3 Post by TwinNut » Thu May 28, 2009 1:03 pm
finn
#4 Post by finn » Thu May 28, 2009 7:28 pm
Just changed my bulbs 1 hour ago to LED. the pins are offset, and yes there is not much clearance but eventually its fitted.
Finn
