Anyone got a spare L/H clip-on?
TwinNut
#1 Post by TwinNut » Tue May 19, 2009 1:06 pm
#2 Post by Aladinsaneuk » Tue May 19, 2009 1:50 pm
i did mine in a vice - but...
sorry i do not have one spare
TwinNut
#3 Post by TwinNut » Tue May 19, 2009 2:15 pm
Chabby
#4 Post by Chabby » Tue May 19, 2009 10:27 pm
TwinNut wrote:On another note does the clipons over tripleclamp make it twitchy as ba*****d? I'm thinking it's an option in the short term but it had to steepen the steering head angle big-time and I don't to tank slap my way down the road.
Why not drop the forks thru' the yokes without moving the clip ons first - If you find it handles ok then move the clip ons on top.
My clip ons are still under the yoke but the bike was showing 3 rings above the yoke when I bought it and it handles fine.
#5 Post by Aladinsaneuk » Tue May 19, 2009 10:30 pm
little bit of heat and then used the jaws of the vice to line things up
and bars over triple does not make it twitchy BUT - having said that, I am using a nice ohlins flavoured steering damper set to 6 clicks....
TwinNut
#6 Post by TwinNut » Wed May 20, 2009 8:17 am
#7 Post by D-Rider » Wed May 20, 2009 10:14 am
I'm still on the standard 3 rings above - but my rear ohlins ride height is maxed out and I've no hint of needing a steering damper.
For a standard rear ride height I'm fairly convinced that dropping the front a few rings more is not going to be a problem - especially if you have a steering damper fitted.
The safe way is to drop the yokes down the forks a ring at a time and see how it goes.
#8 Post by Aladinsaneuk » Wed May 20, 2009 11:16 am
three will be fine mate
