Load more random questions from another Aprilia owner
TwinNut
#1 Post by TwinNut » Mon May 18, 2009 4:12 pm
bigun
AP RS Legend
#2 Post by bigun » Mon May 18, 2009 4:57 pm
I might know some answers;
1. You can buy db killers off the shelf so to speak. You'll need to adapt your exhausts to fit them ie drill small hole in end and rivet or small bolt so you can rmove them if you like. You'll need to measure the internal diameter etc but should be readily available on ebay.
2. If you PM Greg-D, he's in the process of getting some adaptors made up to fit GSXR mirrors with built in LED's. They're a lot more available and you can get pattern parts which are a lot cheaper. Might be worth a look?
5. Decals - try www.the-image-works.co.uk can do anything you like. Excellent prices too.
HTH :smt002
Paul
Bigun
paddyz1
#3 Post by paddyz1 » Mon May 18, 2009 5:16 pm
I presume you are on about these indicators
https://www.ridersite.com/viewtopic.php?t=1224 (scroll down)
The answer is DON'T
Thay are too big and they snap easy with the slightest knock. The rubber is poorly made. You can fix them but you need to 'shim' them with two thin strips of rubber and some decent glue in order to mate the two broken bits together.
GregD-UK
Parts...
#4 Post by GregD-UK » Mon May 18, 2009 5:22 pm
Brake pipe clips £0.51p from any aprilia dealership, ask for the newer clips off an rsvr :smt002 Indicators, still waiting for Mk II mould from manufacturer to be finished :smt010 Let you all know, when available...
TwinNut
#5 Post by TwinNut » Tue May 19, 2009 12:28 pm
TwinNut
Re: Load more random questions from another Aprilia owner
#6 Post by TwinNut » Fri May 29, 2009 2:32 pm
#7 Post by D-Rider » Fri May 29, 2009 5:33 pm
TwinNut wrote:After following up the links and calling around I'm still on the hunt for:
- those little spring-clips (finger pinch type) that hold brake pipes to the master cylinders? - called the local Aprilia dealers and (almost unbelievably) none of them have any in stock, not even in the workshops. Is there anywhere online that these can be ordered from?
Have you tried a Ducati dealer? - a good number of their bikes have the same braking systems .... and they tend to be cheaper too ....
TwinNut wrote: - some small 'Aprilia' and 'Aprilia Racing' stickers that are often fitted on the end of the front mudguard available anywhere?
Ebay can be your friend .... try something like "Aprilia decals" .... there will probably be a load of junk to wade through but you should find something.
TwinNut wrote: - would also appreciate knowing if anyone has a spare set of late RSV-R mirrors with integral indicators? Long shot I know but worth a shot.......or failing that where (other than ebay) the cheapest place to source them is.
Tah.
Sorry, can't help with this one.
Pierre
#8 Post by Pierre » Mon Jun 01, 2009 3:38 pm
Late as usual :smt002
Ebay has the brake line clips, although they arent an exact copy and are more expensive than aprilia (!) but you dont have to get off your arse to get them
edit:balls, link wont work . Search for "fuel line clips" in this shop :- http://stores.shop.ebay.co.uk/Motorcycl ... QQ_armrsZ1 £2.85 for 4 delivered
