Throttle cables ??????
sthomson1
#1 Post by sthomson1 » Tue Apr 28, 2009 5:06 pm
On a standard Falco, where are the throttle cables routed ?
cheers steve
shootmyscoot
#2 Post by shootmyscoot » Tue Apr 28, 2009 7:39 pm
umm i think they run behind the fork stem then in front of the frame, im sure some 1 will correct me?
i have rsv cables, which are much longer
sms
sthomson1
#3 Post by sthomson1 » Tue Apr 28, 2009 8:15 pm
Ive got my cables running in front of the forks around the headstock, between the tank and frame to the throttle bodies .... is this correct ?
It doesn't look right !!!!
#4 Post by Falcopops » Tue Apr 28, 2009 9:33 pm
sthomson1 wrote:Ive got my cables running in front of the forks around the headstock, between the tank and frame to the throttle bodies .... is this correct ?
Nearly, and I'm prepared to be corrected, IIRC they run from the throttle, behind the right fork leg, in front of the head stock then between the frame and tank.
sl1000_dk
#5 Post by sl1000_dk » Tue Apr 28, 2009 9:50 pm
Some old pictures, and i havent changed anything.
sthomson1
#6 Post by sthomson1 » Wed Apr 29, 2009 4:33 pm
Thanks guys, those pictured really helped.
steve
