Clutch slave cylinder seal
I'm being lazy, guys. To save me stripping the cylinder before I get a new seal, would someone please confirm which part on the attached diagram is the seal. Is it number 24, described as a gasket?
The diagram isn't 100% clear to me; that part could be a sealing gsaket for the two pump halves. However, there's nothing else shown as a seal so in the absence of any wise counsel, that's what I'll order. Or maybe I'll just strip it and check! Thanks in advance.[/b]
Oops! Sorry. Try again.https://www.apriliayorkshire.co.uk/cata ... tch%20pump
Clutch Seal No.24
Hi! all
have just bought a new seal from my local Aprilia dealer in N.Baddersley. With club discount, just over £13. Quite expensive really considering it's just a rubber seal.
Ade.
Ade.
Check the Aprilia Technical section ..... alternative compatible seal unearthed costing £2.10 ....
To save you the effort, here's a LINK
