adding oil
finn
adding oil
#1 Post by finn » Sun Apr 12, 2009 9:24 pm
I have a scheduled oil/filter change in two weeks, but i think i need to add some oil as its very low. I dont know what oil is in it now, will it be a big no-no if the oil is mixed full/semi..
#2 Post by Aladinsaneuk » Sun Apr 12, 2009 10:12 pm
i would use semi..... just to be safe
if you only need a little bit - like 250 mls i think then buying a 5 litre pot would be a good idea before your oil change....
sabestian
#3 Post by sabestian » Mon Apr 13, 2009 7:15 pm
Can you mix different brands if the parameters stay the same (ie 10W 40 semi or whatever)?
#4 Post by fastasfcuk » Mon Apr 13, 2009 7:31 pm
sabestian wrote:Can you mix different brands if the parameters stay the same (ie 10W 40 semi or whatever)?
yep
#5 Post by Fausto » Tue Apr 14, 2009 2:37 pm
It's pretty much unavoidable so I'd say yes too.
