10 days with the stock chip and have not had a problem, everything is just fine. Today i then desided to put in the Gabro chip and together with a friend with much more knowledge on bikes than me, we did some small adjustments which Gabro suggested. Fired up like a dream, idle a bit high but think thats normal, managed to get it down to 1300 rpm which sound ok. no smell of gasoline and even the exhaust smoke was nearly gone compare to pre adjustment. Took it for a ride....
so much more pull from low rpm. So lessons learned.. new chip is not allways plug and play.
