I bought the Falco a few weeks back and kept it locked until my SV insurance has expired. So I've started using it for (relatively short) commuting from this week.
The commute isn't anything special so nothing to report there...
Friday was a busy day... First the MOT, then some work done: wire mod, started relay, scottoiler. And I've taken the beast out for what I can honestly say was my first proper run...
JEEEEZZZZ!! That was a good run, resulted in around 60 miles, nice twisty A roads. Me and the bike are getting along better with every mile :)
There are 1 or 2 things I need to find out...
I've cleaned the rotor buttons but there's still a bit of pulsation in the brake lever, is there anything more that can be done (use toothbrush, more cleaning)?
The second thing is the battery, I had 1 or two resets before the mod and the new relay. I'm also using a Oxford Maximiser365.
Bike started fine after every stop today, when I came back home, I've plugged the maximiser and after 2 minuter of "charging" it switched to "maintain" mode.
I'm wondering if it's necessary to plug it in every time?
